KARAOKE SCENE MAGAZINE ONLINE! - Karma Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 10:07 am
 Post subject: Karma
PostPosted: Thu Jul 01, 2010 10:00 am
I am having a problem with Karma giving me a message that reads : THE REQUESTED OPERATION CANNOT PERFORM ON FILE WITH A USER MAPPED SECTION OPEN "I have been using Karma for about 2 years on 2 different computers and only recently have I got this message and only on one of my systems.I can play a song from the menu but if I try to play from the singer rotation it does this and will not let you play the song.All my files are zipped on both systems and has never been a problem .I have updated Karma and it was no help.I may remove from that system and reload but before I do I would like to know if anyone else has had this problem
Thanks,
nburch
 Post subject: Re: Karma
PostPosted: Thu Jul 01, 2010 10:16 am
Just in case someone here doesn't know the answer:
http://latshawsystems.com/TechSupport.aspx
PostPosted: Thu Jul 01, 2010 10:21 am
Tried Latshaw and was told I probably needed to unzip the files,seems I would have had problems for the past two years if that was the case.I will wait a couple of days to see if I get a response and if I dont I will reinstall and post how that goes.
PostPosted: Thu Jul 01, 2010 1:10 pm
Are you running AVG virus software on your computer? It has been noted that it can cause this problem.
If you are not what I would do is delete Karma and don't forget to delete Microsoft Visual C++ 2005 Redistribute (done through the control page and add or remove programs) then download Karma again and it will reinstall C++.
If you are running AVG delete it and try Karma again.
I don't think unzipping will help. I run Karma and all my files are zipped.
You could try unzipping a few and try to see if it makes a difference.
PostPosted: Thu Jul 01, 2010 2:08 pm
Thank you Lone Wolf,that solved my problem.I appreciate the quick response and I will forward the info to Latshaw .
From what I've seen on here in the past,you are the problem solver
Thanks again
tburch
PostPosted: Fri Jul 02, 2010 6:24 am
Thanks again
tburch
Which part?
PostPosted: Fri Jul 02, 2010 7:30 am
Just took out AVG and that did the trick.Did not need to reinstall.
Thanks again
PostPosted: Sat Jul 03, 2010 6:08 am
Thanks again
I run AVG with that same hoster and to date haven`t experienced that problem.
Gator
PostPosted: Sat Jul 03, 2010 6:39 am
I use to run AVG on my computers (except the laptop) and I noticed it slowed down even my fastest computer as it checks everything you do, every time you open a different folder, run a program that you could have had for years it checks it. Finally got rid of it now computers are back up to speed.
PostPosted: Sat Jul 03, 2010 9:31 am
Been Liked: 54 times
I switched a while ago from AVG to AVAST. They also have a free version and it seems to be not as resource hogging as AVG. I run CompuHost with it and never had a problem so far.
Here is a link:
http://download.cnet.com/Avast-Free-Ant ... tag=button
PostPosted: Sun Jul 04, 2010 8:38 am
Been Liked: 15 times
I switched from AVG to AVAST a year or more ago at the suggestion of Morgan Lafey here at Karaoke Scene and as much as I liked AVG and THOUGHT it was the best, I found out AVAST is better. It doesn't let anything get through and it doesn't seem to low the computer down at all. I have not had any problems with viruses or Trojans since I switched. AVAST works FAR BETTER than Norton or Mcafee. I would never use either one.
If there is a conflict between the antivirus and an application program like Karma, it's pretty simple and easy to just deactivate the internet and shut the antivirus program down during a Karaoke show. Although, I don't know for sure that doing that would alleviate the conflict with Karma since I don't use it.
Users browsing this forum: No registered users and 2225 guests
