External Pro USB Soundcards etc
https://ksmo.us/forums/viewtopic.php?f=1&t=19625
Author:  jamkaraoke [ Mon Jun 14, 2010 10:13 am ]
Post subject:  External Pro USB Soundcards etc
Do external soundcards like below have any effect on overal volume ?
http://www.adjaudio.com/ProductDetails. ... ategory=21
Or is volume coming from the laptop determined by
a) Laptops sound card?
b) Progam playing the mp3+g ?
c) both
Reason for my question is... I don't feel I am getting all the potential VOLUME out of my system. YES I can turn the amp/mixer l UP and UP but I know that the sound coming IN isn't all that it should be. The METERS are hardly moving on the amp/mixer which to me is inidicating not enough signal going IN. The laptop SOUND is at 100% as is the soundcards output. Even the hosting program volume is at 100%-- Are there any other settings on the laptop I could be missing??
What am I missing ?
Author:  Lonman [ Mon Jun 14, 2010 10:22 am ]
Post subject:  Re: External Pro USB Soundcards etc
Could be a bit of both - but I would say more toward the card itself. Some programs have a volume control, but usually that is the overall volume in the system.
I can tell you the difference in my laptops sound card & the Lexicon external I bought for it is night & day. Best $80 I spent. Darn thing sounds as good as the $200 card I have installed in my desktop.
Author:  tim_aka_tim [ Mon Jun 14, 2010 11:17 am ]
Could it be that your soundcard is a -10dB line out whereas your mixer/amp is expecting a +4dB line? Many mixers have a switch for the input line level on that channel.
Author:  Lonman [ Mon Jun 14, 2010 12:55 pm ]
Most budget mixers do not have the +4/-10 switch.
Author:  jamkaraoke [ Mon Jun 14, 2010 1:12 pm ]
The extrenal soundcard is listed above --VERSA PORT. I do not believe its a -10dB.
I'm also using the Yamaha EMX512 which --I'll have to check -- I don't believe its has a +10db switch.
Author:  tim_aka_tim [ Mon Jun 14, 2010 1:17 pm ]
Have you tried two mic inputs, panned to L & R, and slowly turning up the gain to get a decent level. Pain though, cus now you have 2 faders to control for the music.
The manual for the USB sound card doesn't list it's line level (that I can see).
Edit: Seen what mixer you have, and looks like you have no pan.
Author:  Micky [ Mon Jun 14, 2010 3:58 pm ]
This external card uses RCA connections so it's not balanced and therefore its a -10db.
Does your mixer have sliders? You might want set the level to +10db if it doesn't have the +4db option :wink:
Author:  tim_aka_tim [ Tue Jun 15, 2010 5:54 am ]
The mixer does have RCA inputs, which should be -10dB. It's a long shot, but open your sound card control panel and see if you can tell that you're using headphones instead of speakers - that boosts the volume on some sound cards with certain drivers.
Author:  jamkaraoke [ Tue Jun 15, 2010 8:29 am ]
Currently using RCA to 1/4" cables from the External Card to the Mixer.
Am I better off going into the RCA on the mixer ? or makes no difference ?
Author:  jamkaraoke [ Tue Jun 15, 2010 8:30 am ]
Author:  mckyj57 [ Tue Jun 15, 2010 8:37 am ]
I don't understand the problem here. If you bring it into a full stereo channel on the mixer, the preamp gain adjustment should be able to handle any range you send it.
Author:  tim_aka_tim [ Tue Jun 15, 2010 8:37 am ]
If you have some rca to rca cables, give it a go, though the specs in the mixer's manual suggest that the rca and phone socket are the same input level.
Author:  jamkaraoke [ Tue Jun 15, 2010 8:59 am ]
The problem may be just "me" lol. As stated It just appears that I am not getting the full sound out of my laptop/external soundcard even though both seem to be at 100% volume. I am going to do a comparison using the same mpe3+g file and play it a few different ways using the same settings on the mixer
Once using the external card and then using the laptops card.
I'll even compare the 2 hosting programs I use to see what happens and if the volume changes
Author:  mckyj57 [ Tue Jun 15, 2010 9:01 am ]
Then you must be going into some crippled thing like "CD in". I can't see how you couldn't get proper output when you go into a standard stereo channel with a preamp and trim/gain control.
Author:  jamkaraoke [ Tue Jun 15, 2010 10:02 am ]
Not using "cd in" but going into one of the stereo channels.
Author:  tim_aka_tim [ Tue Jun 15, 2010 10:37 am ]
Had another look at the manual for your mixer, and it's line ins, both phone and rca are nominally +5dB. This might be like teaching your grandmother to suck eggs, but line levels come in 2 flavors, -10dB consumer level and +4dB pro level. Consumer levels come from cd players, dvd players and computer sound cards. The mixer is expecting +4dB pro level inputs, hence it's very quiet.
If you plug the soundcard into channels 3 and 4 and press input switch to 'mic', it will be set to -25dB. Set the level knob to a low level and turn it up until it's loud enough. Unfortunately though, that will use 2 mic channels and be mono.
Had the same problem on my mixer, but fortunately have a -10/+4 switch.
Author:  mckyj57 [ Tue Jun 15, 2010 12:42 pm ]
What mixer? Is it the EMX512? I could see how that could happen, then, because there is no separate pre-amp TRIM control only the LEVEL knob.
When it seems I had that same problem a couple times, I went into the sound controller driver controls and found the volume was set at 50%. (This is separate from the master volume.) I turn it up there, and the problem goes away.
Author:  jamkaraoke [ Tue Jun 15, 2010 1:30 pm ]
Thanks everyone for the replies
I'll fool around tonight if I can with the soundcard/software/driver etc and see if any of the volume/gain settings can be increased.
