KARAOKE SCENE MAGAZINE ONLINE! - Snake modifaction....change xlr to 1/4 Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 6:31 am
PostPosted: Thu Jun 10, 2010 6:40 pm
Been Liked: 53 times
I am modifying my snake at the HEAD end. utting a 1/4" mono end (removing XLR) so I can run my monitor signal over the snake to a powered speaker (with XLR input) at the stage.
Questioning my thinking on the soldering.......
XLR PIN 1 (gnd) & 3 (cold -ve)....Both go to Sleve/Grnd on the 1/4" plug
XLR Pin 2 (hot +ve)...goes to the TIP on the 1/4" plug
Am I correct ????????????????????????????
PostPosted: Thu Jun 10, 2010 7:21 pm
Why not just use a patch cable?
PostPosted: Thu Jun 10, 2010 8:51 pm
Or an adapter. that is what I am using to connect my new mikes to my mixer.
http://cgi.ebay.com/Lot-2-XLR-Female-Ja ... 53e14e5a46
PostPosted: Fri Jun 11, 2010 1:37 am
Most powered speakers take unbalanced signals, and if not, use an adapter as suggested, no need to take apart a perfectly good cabling system.
PostPosted: Fri Jun 11, 2010 6:27 am
Yes.
PostPosted: Fri Jun 11, 2010 10:51 am
Do not put an unbalanced TS connector on your snake. That's just foolish. Get a TRS connector so you have all three conductors wired when you need them.
I understand why you would want to change the ends instead of use adapters, which are easily lost or stolen. If I were you, though, I'd just secure adapters to the XLR ends with tape so they won't get lost. Going from XLR to TRS is a step backward.
Jeff Wheeler, moonlight DJ/KJ
PostPosted: Fri Jun 11, 2010 4:07 pm
Yes.
Thanks.
Yes I was going to get the adapter, but I just got a gig where I will need to use it to run a monitor signal to the stage, and the gig is Saturday. No time to order an adapter. And the local "pro audio" guy has no clue or adapters.
Users browsing this forum: No registered users and 2526 guests
