KARAOKE SCENE MAGAZINE ONLINE! - Ripping Utility Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 12:23 pm
 Post subject: Ripping Utility
PostPosted: Sat May 15, 2010 6:05 am
Looking for opinions on the best ripping utilities.....
Gator
 Post subject: Re: Ripping Utility
PostPosted: Sat May 15, 2010 1:07 pm
Been Liked: 81 times
I use two programs. The primary one is CDGRip w/Fasttracks 2 as the database. The only problem I've had is that CDGRip has issues with the copy protection in the final track. To get around this I also use Power CD+G Burner for the final track.
The Power program actually rips a little faster but uses the internet free database to name the tracks. The problem with this is, that depending on who enters the information, you generally spend more time correcting the info to conform to standards than you save.
It's actually faster to have both programs loaded and use CDGRip for everything but the track that has the copy protection and then use Power for the final track.
PostPosted: Sat May 15, 2010 2:12 pm
I use MTU Hoster to rip all the music I use for the gigs. For ripping music for personal use, I also use Power CD+G Burner. Never failed me so far with that.
Seize the day and SING!!!
PostPosted: Mon May 17, 2010 3:09 am
I Have both programs but CDGRip does seem to rip the last song so far?
Gator
PostPosted: Mon May 17, 2010 6:01 am
I use CDGrip with fasttracks2 and never had a problem with the last track.
PostPosted: Mon May 17, 2010 3:07 pm
Same here also using both programs and no problem with last track.
Gator
PostPosted: Sat May 22, 2010 8:03 am
Would that program also rip scdg?
Gator
PostPosted: Sat May 22, 2010 8:22 am
no you need to get karaoke file converter from www.roxbox.net to rip those songs.
PostPosted: Sat May 22, 2010 11:34 pm
You Are absolutely sure that program will do it?
Gator
PostPosted: Mon May 24, 2010 11:30 am
Karaoke file converter from www.roxbox.net is what I use to rip SCDG's. It also rips NEO discs.
Users browsing this forum: No registered users and 2169 guests
