KARAOKE SCENE MAGAZINE ONLINE! - PA System - EQ'ing Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 1:27 pm
 Post subject: PA System - EQ'ing
PostPosted: Fri Apr 30, 2010 3:20 am
What is the name of the device pro-stage audio tech's use to send noise through the PA upon initial set up in a room(venue) to do the initial setting of the system? How does that work? Does anybody here use this?
 Post subject: Re: PA System - EQ'ing
PostPosted: Fri Apr 30, 2010 5:43 am
It is called a Real Time Analyzer. It uses "Pink Noise" to set a rooms EQ flat. Pink Noise is a sound that carries equal amounts of noise power in each octave. A special calibrated mic can then "listen" to that noise and detect differences. Since the noise is equal across the spectrum, if the mic pick up inequalities you know it is the room causing them and you can adjust an EQ to compensate.
PostPosted: Fri Apr 30, 2010 9:09 am
I don't use them, when I have, I usually end up re-eq'ing anyway to what sounds better or for some feedback issues. Plus it's very annoying sending a loud blast of pink noise through the PA for a few minutes - the bar staff & patrons just LOVE that sound at high volumes.
PostPosted: Fri Apr 30, 2010 10:03 am
Lonman @ Fri Apr 30, 2010 9:09 am wrote:
...the bar staff & patrons just LOVE that sound at high volumes.
I Know I do... :)
Users browsing this forum: No registered users and 2037 guests
