KARAOKE SCENE MAGAZINE ONLINE! - compuhost crawler issue Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 2:16 pm
 Post subject: compuhost crawler issue
PostPosted: Fri Apr 16, 2010 7:10 pm
during a show the other night the text size on the crawler changed and now can barely be seen. there is nothing within compuhost to adjust this so i am at a loss. anyone out there have this problem before and if so what did you do to fix it?
PostPosted: Sat Apr 17, 2010 12:11 am
Been Liked: 81 times
Wow, that's a new one. Have you tried reloading the crawl? Is it still an issue after reloading the program? While it's possible to change the font, I don't see anyway to change the size.
You may want to go to the CH forum and file a report with tech support on that one.
PostPosted: Sat Apr 17, 2010 1:55 pm
I thought of re-installing but I am afraid I'll loose all singer data. When not using a secondary screen it's fine. It's bizarre. Thanks for the reply and recommending the CH forum.
PostPosted: Sat Apr 17, 2010 9:36 pm
I don't see why you would. Back up the "c:\Program Files\CompuHost" directory before you upgrade to be safe -- you should do that anyway.
I would try File --> Create New Setup and see if it changes back.
And what version are you using?
Users browsing this forum: No registered users and 2156 guests
