[ 13 posts ] |
neonmoon
Posted: Thu Mar 25, 2010 8:49 am |
| Major Poster |
Joined: Thu Feb 14, 2008 11:39 am Posts: 68 Location: Kansas, Lawrence area Been Liked: 0 time
I have recently switched from running cd's to Hoster, It runs great, and has made hosting much easier, but occasionally the singers have trouble keeping up with the song. When running disc I had the option to slow things down, can anyone tell me is there a way to do this with hoster? Thanks for any help...Cord
_________________ I'll be alright as long as there's light from a neon moon
Posted: Thu Mar 25, 2010 10:23 am |
Which player were you using that you could speed or slow down?
Currently Hoster does not have this feature, however they are working on it.
fsapienjr
Posted: Thu Mar 25, 2010 10:51 am |
| Advanced Poster |
Joined: Mon Jun 11, 2007 4:55 pm Posts: 326 Location: Los Angeles, Anaheim, Glendora Been Liked: 2 times
What do you mean not able to keep up? Are you saying that the song is playing correctly, the graphics are in sync, and they just want to slow everything down? If that is so, then Lonman is right. The 4.2 realease of Hoster will have tempo as an adjustment.
On my system, playing off of the hard drive, my graphics are not in sync with my music. The graphics are a little behind where they should be. Under Tool then Options, I think, I have to set the offset to -.5, and everthing runs like a champ off of the hard drive.
Felix the KJ
neonmoon
Posted: Thu Mar 25, 2010 12:25 pm |
| Major Poster |
Lonman i ran a Vocopro cdg 9000 for the last three years it was time to replace and decided to put the money towards going laptop. I just could not find any info on the feature on hoster. thanks for the info....Cord
neonmoon
Posted: Thu Mar 25, 2010 12:37 pm |
| Major Poster |
Felix, yes they are just having trouble keeping up on certain songs, everything is in sync. I will keep running as is until the update you speak of. Other than having to load all the cdg,s for hoster everything else is great, it has taken the burden of hustling disc all night and I couldn't be happier. I wish I would have went this route before!
Posted: Thu Mar 25, 2010 12:44 pm |
neonmoon @ Thu Mar 25, 2010 1:25 pm wrote: Lonman i ran a Vocopro cdg 9000 for the last three years it was time to replace and decided to put the money towards going laptop. I just could not find any info on the feature on hoster. thanks for the info....Cord
Ah. Only problem with that system (at least the original) is it also changes the key when you speed up or slow down. Did that change on the later models?
TopherM
Posted: Thu Mar 25, 2010 12:50 pm |
How much video memory do you have on your laptop? This is the most common cause of the lag.
If it is just a little off, you may just have to free up a little bit of FSB memory in your laptop to get it to work correctly. Make sure you are running in "HIGH PERFORMANCE" mode in the power settings, as opposed to the default mode or energy saving mode. Also make sure that you turn as many background programs off as possible while running Hoster. The biggest memory hogs are any AntiVirus programs and ESPECIALLY the Microsoft Indexing Service. If either of those are running, and you turn them off, it will probably fix your lag problem.
I had a computer that could BARELY run CompuHost when I first got it, and the lag was like 2-3 seconds between the music and lyrics, but just turning off the MS Indexing Service put everything in sync. It is all about available memory!
_________________ C Mc
neonmoon
Posted: Thu Mar 25, 2010 12:55 pm |
| Major Poster |
Lonman, on the model I have it is seperate I know most on here are not fans of Vocopro Mine served its purpose well I gave it a good cleaning and left it mounted to play customer cdg's At the time it was the only dual player I could find with the features i wanted...Cord
Posted: Thu Mar 25, 2010 12:57 pm |
TopherM @ Thu Mar 25, 2010 1:50 pm wrote: How much video memory do you have on your laptop? This is the most common cause of the lag.
He doesn't have a lag in graphics or out of sync graphics, he wants to be able to slow or speed the song over all - tempo change.
exweedfarmer
Posted: Thu Mar 25, 2010 2:57 pm |
"Tweak the singer not the equipment." is my motto. It seems clear to me that the machine is doing what it's supposed to. There is no need for a work around, just fix the problem.
Karen K
Posted: Thu Mar 25, 2010 9:37 pm |
TopherM @ Thu Mar 25, 2010 12:50 pm wrote: How much video memory do you have on your laptop? This is the most common cause of the lag.
I am so NOT a computer person - can you explain exactly how I can see if these things are running and how to turn them off? Ctrl Alt D? Then performance/applications? I don't need anything extra running - that may actually get rid of my slight occasional "burp" that occurs some time after I load a private CDG....I just don't want to get too exuberant and do something I shouldn't do. Thanks for the info so far.
k
RLC
Posted: Fri Mar 26, 2010 2:52 am |
Karen K @ Thu Mar 25, 2010 11:37 pm wrote: TopherM @ Thu Mar 25, 2010 12:50 pm wrote: How much video memory do you have on your laptop? This is the most common cause of the lag.
I had a computer that could BARELY run CompuHost when I first got it, and the lag was like 2-3 seconds between the music and lyrics, but just turning off the MS Indexing Service put everything in sync. It is all about available memory! I am so NOT a computer person - can you explain exactly how I can see if these things are running and how to turn them off? Ctrl Alt D? Then performance/applications? I don't need anything extra running - that may actually get rid of my slight occasional "burp" that occurs some time after I load a private CDG....I just don't want to get too exuberant and do something I shouldn't do. Thanks for the info so far. k
Karen, here is a little utility I use -> http://download.cnet.com/GameMode/3000- ... 07864.html
It closes all non essential applications and then will restart them when you want to.
I actually also close this program once it has finished closing all non essentials as well-knowing that shutdown and restart of the computer will restore everything as well.
Karen K
Posted: Fri Mar 26, 2010 8:07 am |
Thanks for the tip. Will try that today.
[ 13 posts ] |
Users browsing this forum: No registered users and 2000 guests |
