KARAOKE SCENE MAGAZINE ONLINE! - video question Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 4:25 pm
 Post subject: video question
PostPosted: Sun Mar 21, 2010 2:31 pm
Hello everyone,
I need some help on hooking up to more than one tv. I am interested in wireless connections for numerous tv's and was wondering the best way to go about it. I use compuhost and have a vga converter LKV-2000 for my monitor and one other bar tv but they are "wired". HELP.
 Post subject: Re: video question
PostPosted: Sun Mar 21, 2010 7:36 pm
For real?? No help? C'mon, I'm lost as an easter egg here! thanks
PostPosted: Mon Mar 22, 2010 4:00 am
Many bar TV sets have multiple inputs..
I hook up a wire and change the channel..
PostPosted: Mon Mar 22, 2010 6:36 am
Been Liked: 20 times
I think what you're looking for is a wireless video tranmitter, and receiver. They are all over the net. Just do a search for wireless video tranmitter. Hope this helps.
Rosario
PostPosted: Mon Mar 22, 2010 9:47 am
You would have to have a receiver for each TV and not sure if one transmitter would cover it as they have to be a matched pair in the send/receive frequencies. You could buy a lot of cable for what it would cost to do this. If you are in a permanent club it might be worth running cable.
Just like srnitynow said do a search (i did) and you will come up with lots of choices.
PostPosted: Mon Mar 22, 2010 11:08 am
I have weekly gigs here and there and would just like the option of hooking into more than one tv without the hassle of more wires, etc. Wireless senders, are indeed all over the net i was just wondering if anyone had any particular one they could recommend. Thanks for the help, I aprreciate it!
PostPosted: Mon Mar 22, 2010 2:32 pm
I have and on occasion use the X10 Wireless Video Sender but I think with this particular unit, to use more than one you would need a sender for every receiver.
Both the sender and receiver have a power plugin as well as the video cable so either way you are still messing with cables of one sort or another. As stated, if you can just connect with coax, RCA or s-vid that would be my first choice as well.
Most of the bars I have worked have multiple TVs "in line" so just hook up to one and set the channels on them all and away you go.
PostPosted: Mon Mar 22, 2010 3:07 pm
spotlightjr @ Sun Mar 21, 2010 2:31 pm wrote:
Hello everyone,
At the chicken wing place down the street from me uses some kind of mini dish system? I spy a little transmitter on the wall, and then 3 projectors, suspeneded from the cieling, each have a little "dish" mounted on them. The thing works, okay, lotta dropped frames, etc.
Mark
PostPosted: Tue Mar 23, 2010 12:08 pm
All my gigs have one to three plasmas per venue. All but one can be reached with a 25' cable. My thuesday gig I have a permanent 50' cable to the furthest plasma.
Wireless video and speakers are hasles I prefer to keep out of my setup. If it is a permanent gig, run cables, speakers or video.
Felix the KJ
8)
PostPosted: Wed Mar 24, 2010 1:06 pm
Well wire is cheap. Most likely bars do not use any of the other inputs on their tvs. I lucked out all the places I work have s-video on their tvs. I just perminatly installed wire at all 4 of the bars that I work.
I suggest monoprice.com for your cables. and s-video splitters are only $3.
PostPosted: Wed Mar 24, 2010 7:43 pm
www.monoprice.com is the place to go.
PostPosted: Thu Mar 25, 2010 1:42 am
Find out where the central sender is where it is split from & connect right before that in whatever form it is - 9 out of 10 times it's still coax from my experience. Convert your signal to that & go through their spilitter.
PostPosted: Fri Mar 26, 2010 11:14 am
thx lonman, it makes sense and I will check it out
PostPosted: Wed Mar 31, 2010 9:35 pm
I was looking for something like this as I had a similar problem but I didn't have a practical solution from here. Is there anyone who really tried it??
video sender
PostPosted: Thu Apr 01, 2010 12:35 am
Tried what? I've hooked into the central sending unit to get the signal to all tv's in the house before.
Users browsing this forum: No registered users and 2004 guests
