Joined: Mon Mar 01, 2010 12:43 pm Posts: 3912 Images:13 Been Liked:1672 times
Any of you guys familiar with this unit? It's the "Cher" effect from her song Believe and now used popularly by T-Pain. I would like to buy one for my home karaoke set up but I don't know how to set it up. Back panel Main Line Out is 1/4" T/S phone plug and Line Input says it's not a microphone input (huh???). I thought I can plug my mic to this unit in, out to in my echo/rev/delay unit - out to In Mixer. Mixer does not have inserts. Advice?,
Joined: Tue Apr 14, 2009 8:53 am Posts: 1462 Location: West Bend, WI Been Liked:3 times
No you cannot plug a microphone directly into it. It's just like any other effects or dynamics processor, it is expecting a line level signal not a mic level signal. If your mixer does not have inserts then about the only way you could do this would be to buy an external mic pre-amp connect your mic to the pre-amp, your pre-amp to the line in on the AVP-1 and then the output of the AVP-1 to the line in of your mixer channel.
There are computer based solutions that would probably be a lot easier for you to deal with than that AVP-1. That's a pretty complex and powerful unit with a big learning curve.
Users browsing this forum: No registered users and 1868 guests
