Dr Fred
Posted: Sat Mar 06, 2010 10:52 am |
Joined: Wed Aug 22, 2007 5:22 pm Posts: 1128 Location: Athens, GA Been Liked: 4 times
Just wondering how often different KJs use reverb/delay etc.
I personally very rarely use it.
I have only had it requested about 3-4 times in about 200 shows by the singers.
Posted: Sat Mar 06, 2010 11:22 am |
I wouldn't run vocals dry, there's not a song in nearly every song in recorded history that doesn't have some kind of effect (at least a reverb) at minimum on vocals - even with live music, effects on vocals are pretty standard.
I often will run a reverb and delay combo depending on the song - just enough to not really notice (unless the song calls for it ie 7 - Prince or lots of 50's songs with the prominent backslap delay) but you would notice if nothing was there. Effects should enhance the vocals but never overpower - again there are some songs that do require it but usually a simple reveb at minimum is all one needs.
Surprising you have never had a request for it, I get people that are always asking for more - which I can just put in their monitor without affecting the main mix. I personally prefer a little reverb at minimum when I sing.
c. staley
Posted: Sat Mar 06, 2010 1:05 pm |
| Extreme Poster |
Joined: Thu Jun 06, 2002 7:26 am Posts: 4839 Location: In your head rent-free Been Liked: 583 times
I won't sing through a dry system.... ever.
I won't sing though a system that sounds like you're in a tunnel either.... ever.
johnny reverb
Posted: Sat Mar 06, 2010 2:36 pm |
| Extreme Poster |
karaoke without adding some vocal effects, at least a bit of reverb......almost unheard of.......  ......being a Botanist, working as a KJ.....I thought you'd be more of a Fungi......starting to have my doubts....
exweedfarmer
Posted: Sat Mar 06, 2010 4:10 pm |
All the background tracks are effects-ed up the ying yang. Don't the totally dry vocals sound strange in the mix?
Isn't it odd that people don't comment more on things like that at the shows. I was wondering myself the other day why I so rarely get asked for a key change.
ripman8
Posted: Sat Mar 06, 2010 7:34 pm |
uhhhhhhhhhhhhhhhhh I disagree. Hip hop needs very very little.
exweedfarmer
Posted: Sat Mar 06, 2010 7:38 pm |
ripman8 @ Sat Mar 06, 2010 7:34 pm wrote: uhhhhhhhhhhhhhhhhh I disagree. Hip hop needs very very little.
Good point.
Dr Fred
Posted: Sat Mar 06, 2010 10:27 pm |
johnny reverb @ Sat Mar 06, 2010 6:36 pm wrote: karaoke without adding some vocal effects, at least a bit of reverb......almost unheard of.......  ......being a Botanist, working as a KJ.....I thought you'd be more of a Fungi......starting to have my doubts....
I think my attitude about reverb is that we have a lot of beginning bands in town that use so much reverb that the vocals are just about incomprehensible. With so many local band using way to much reverb, I think most of my following has a negative attitude about it.
Not to say that it cant improve most songs, but depending on how the reverb is set it adds an unexpected level to the singing results, and I think that most of my regulars are used to singing without any.
BigJer
Posted: Sat Mar 06, 2010 10:51 pm |
Joined: Fri Aug 28, 2009 10:42 pm Posts: 1064 Been Liked: 92 times
Most people out to sing karaoke aren't superstar vocalists with incredible natural resonance. Reverb definitely helps.
Posted: Sun Mar 07, 2010 1:22 pm |
Dr Fred @ Sat Mar 06, 2010 11:27 pm wrote: johnny reverb @ Sat Mar 06, 2010 6:36 pm wrote: karaoke without adding some vocal effects, at least a bit of reverb......almost unheard of.......  ......being a Botanist, working as a KJ.....I thought you'd be more of a Fungi......starting to have my doubts....  I think my attitude about reverb is that we have a lot of beginning bands in town that use so much reverb that the vocals are just about incomprehensible. With so many local band using way to much reverb, I think most of my following has a negative attitude about it. Not to say that it cant improve most songs, but depending on how the reverb is set it adds an unexpected level to the singing results, and I think that most of my regulars are used to singing without any.
Doesn't mean it should'nt be used, it should not be 'overused' to the point that it is drowning out the original vocal signal. It should be just an underlying enhancement to where you can't really hear it but notice if it wasn't there. If the live music engineers don't know how to use the effect properly, learn how to use it & apply it properly to your singers - don't just turn it off. They will thank you - maybe not so much in words, but in word of mouth.
enzoab
Posted: Sun Mar 07, 2010 4:08 pm |
Too much use of effects can muddy up the sound as well. I've noticed that a lot of KJ's don't run their mic's through a seperate channel with at least a bass and treble adjustment and the whole sound is sort of muddy and "same sounding", or the music kicks butt and the vocals suck....
I like using a monitor (where I can) with seperate feed adjustments for the music and the vocals. More options is always better since you can't read a room before you play the room.
Good thread.
Mark
Karen K
Posted: Sun Mar 07, 2010 5:47 pm |
As soon as we start talking about effects, someone starts calling all effects "reverb." Good grief, that is possibly the worst example of a vocal effect on its own ... and the most common one, and the most overused. (Maybe it is the only effect available on a cheap system? Don't know for sure.)
Bothers me when I go to a show for the first time and may even be acquainted with the KJ - I take a quick glance at the board to make sure I'm asking for something that is possible, then ask to have a bit of efx added. Some say sure, then do something (not sure what) and think I'll believe they have added effects. In other words, many don't even know HOW to add effects. Nobody sings dry. PERIOD. On the other hand, you should never be able to hear the effects.
Jian
Posted: Sun Mar 07, 2010 6:01 pm |
Dry vocal is like a lady without make-up;
good-look ladies look angelic with make-up
average looking ladies will look very pretty with the right make-up
the so-so looking ladies will be more presentable with proper make-up.
@Dr Fred: try this; use efx on the vocal channel, just enough, and see how many for the singers will request to sing without it.
ps: my above analogy is not meant to be a sexiest statement; if anyone is offended by it I apologized
enzoab
Posted: Sun Mar 07, 2010 6:25 pm |
Agree big time. A bit of reverb, a bit of echo. I have a harmonizer and for the most part I can't use it at anything more than a "bit" as well... Too much of any of these make people sound worse... Well, you know what I mean.
mrscott
Posted: Sun Mar 07, 2010 6:58 pm |
| Super Duper Poster |
Yes, I use at least a little reverb almost all the time, sometimes add a tiny bit when requested. But my belief is "less is more". Can definitely be overpowering at times, but if its not there, then it's very noticeable.
exweedfarmer
Posted: Sun Mar 07, 2010 7:09 pm |
Jian brought up something I missed the first and second reading. Are we talking about fxing the background music or just the vocal chanels? Vocal yes, music no.
Jian
Posted: Sun Mar 07, 2010 8:00 pm |
exweedfarmer @ 8th March 2010, 11:09 am wrote: Jian brought up something I missed the first and second reading. Are we talking about fxing the background music or just the vocal chanels? Vocal yes, music no.
Effect should only be used on vocal ( rarely used for music in karaoke setting)
Eq should be used for both vox and music; mainly as a corrective tool.
stogie
Posted: Sun Mar 07, 2010 8:21 pm |
EFX should only be used on the vocal/mic channel. I don't see any advantage to using effects on the music and in fact it detracts from the music.
I have difficulty understanding why everyone isn't using at least some vocal effects. There is a reason they were developed. Vocal effects make the voice sound richer, fuller and they cover up or disguise SOME vocal defects.
You can't make someone who is very bad sound good, but you can make them sound a bit better. You can certainly enhance even very good singers by adding some vocal effects. Bad is bad, even with vocal effects added, but there is no debating that you can enhance most vocals with properly administered vocal effects.
If you're not using them you're not using a valuable tool that is available and not difficult to use, adjust and master. Nearly every professional singer uses some sort of vocal effects. If it's good enough for professional singers then it's good enough for amateur singers.
enzoab
Posted: Sun Mar 07, 2010 9:10 pm |
Vocal yes, music, no.
As others have said, this is kind of a silly thread. You won't find any popular music on the radio, or even at clubs without everything from reverb to echo to that damn Auto Tune think. T-Pain, I hate you!  . Even classical singers employ some reverb and echo, though lesser that pop singers.
I say bring on the vocal effects, don't over use them and you help not only the singer but the audience as well.
Mark
lyquiddye
Posted: Mon Mar 08, 2010 12:59 am |
I use all the time my normal effect is a Wood Room Reverb, with a slight chorus and a short delay.
Users browsing this forum: No registered users and 2004 guests |
