[ 7 posts ] |
poptop05
Posted: Sat Jan 30, 2010 8:38 pm |
| newbie |
Joined: Sat Jan 30, 2010 8:28 pm Posts: 3 Been Liked: 0 time
We are using a Dell Inspiron 1300 as the base unit for our digital karaoke system, however when the unit is plugged in to charge. (obviously all night), a buzz sound is heard through the PA.
The louder the speakers, the louder the buzz.
Any ideas how to cure this problem
We have tried plugging the power cable to the laptop in a separate power board, no good!
Cheers
Jian
Posted: Sun Jan 31, 2010 1:10 am |
rich b
Posted: Mon Feb 01, 2010 7:28 am |
Joined: Wed Jul 23, 2003 5:49 am Posts: 35 Location: Michigan Been Liked: 0 time
You could also use a 3 prong to 2 prong plug adapter available for 29 cents at your hardware store...
letitrip
Posted: Mon Feb 01, 2010 8:05 am |
Before you buy anything, figure out where the ground loop is coming from. Ensuring all your equipment is plugged into the same ground and eliminating multiple paths to ground is the easiest and BEST way to eliminate a ground loop. If you can't have all your equipment plugged into the same A/C source, look at where you have multiple ground paths and how you can eliminate all but one ground path (through ground lifts on the equipment if so equipped) or how you can isolate them. You can use an isolator like Jian posted but it has to be installed in the right point that will isolate the two separate ground paths from each other.
I would not recommend using a 3 conductor to 2 conductor adapter unless all other options have failed. You want to have your equipment grounded and ensure that the ground path travels through the appropriate type of conductor.
* EDIT * When looking at ground paths, don't forget that the shielding on all of your cables (RCA cables, 1/4" patch cables, VGA, USB, etc) acts as a ground path as well. I've seen the ground on an RCA video cable lead to a ground loop between my equipment and the bar's TV that I plugged into. Ground paths interconnect through all of your equipment so pay attention to all of it.
_________________ DJ Tony
poptop05
Posted: Mon Feb 01, 2010 8:59 pm |
| newbie |
I have ordered a Ground Loop Isolator & RCA Phono Noise Filter IN & OUT
I will try this first, as per first recommendation. As soon as I unplug the laptop power charger, the buzz stops.
Will keep you all posted.
Must say I am thrilled that there are other karaoke people out there that are happy to help
Cheers
Paul
lyquiddye
Posted: Mon Feb 01, 2010 9:09 pm |
Dell notebooks are know for being quite noisy. Ground Loop isolators will help the problem.
High quality power conditioners any Furman over $250 will work.
Also high end amps like QSC PLX, Crown xTi, Anything EV or Dynacord will also reduce hum.
hamsamich
Posted: Mon Feb 01, 2010 11:14 pm |
| Advanced Poster |
Joined: Tue Jul 25, 2006 12:25 pm Posts: 413 Been Liked: 0 time
dude, you need the humX. it is so small and nice. fixed my problem right away. I had the same thing. try that first since it is so small, cheaper and easy.
_________________ [glow=red]Yo sucka, we need this hea CHOPTER, and we need it now![/glow]
[ 7 posts ] |
Users browsing this forum: No registered users and 1663 guests |
