KARAOKE SCENE MAGAZINE ONLINE! - Double Checking My Hook Up Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 6:03 pm
PostPosted: Thu Jan 28, 2010 6:37 pm
Ok this is how i hooked it all up,does everything look good?
zed 12fx from mains i have 3 foot xlr cables going to the yamaha qo2o31b eq
from the eq out i have for now 15 foot xlr cable to 1/4 inch in on the Yamaha P5000S amp.
from the bbe sonic maximizer 882i i have xlr to 1/4 inch insert cables going to the l/r inserts next to main inputs.
The dbx 231 i have 1/4 inch insert cables going to mic channel on zed,only have to do 2 mics
i've never used a separate amp before and i found i had to have the knobs turned up almost 3/4 of the way before i got sound out of my speakers yamha br-15's,does that sound right?i guess i was expecting them to act more like volume control knobs and they don't appear to act that way.
At first i couldn't get anything out of the bbe and oopsy i had the channels crossed!
i have some hum from the eq,hoping shorter cables help.
if i get any more equipment i'm going to have to run another dedicated outlet here soon Lol
One of my problems i see i'm going to have to deal with is that when i run compuhost,i'm not getting any sound out of the speakers.I configured compuhost to use the audio codec,checked volumes and speakers but nothing so far.just trying to take it slow
PostPosted: Fri Jan 29, 2010 1:18 am
Proper way would be:
Main out from mixer to Eq to BBE to amp.
You really don't need and EQ and a BBE.
The input gains on the amp should be all the way up.
The volume is the main out on your mixer.
PostPosted: Fri Jan 29, 2010 3:00 am
Drop the Yamaha EQ (most likely your hum source), replace with the dbx 231. Mixer to dbx eq, eq to amp. Run the BBE as you are with the insert - will work fine. You do not need a 31 band eq for mics.
Like said the mixer is basically the preamp, in this case it sounds like wide open on the amp will work best - those aren't volume controls, they are attenuators to match the mixer to the amp - I tend to run my amps wide open 95% of the time. Your main volume will be the main fader on the mixer.
PostPosted: Fri Jan 29, 2010 4:22 am
ah i wrote the one wrong,i don't have a dbx231 i meant dbx 266xl compressor,that's why they are going to mic input so i can compress mics not music.
So mixer to eq,eq to amp,bbe to inserts (since it's more a frequency aligner not an eq)then 266 to mic channel.
i got the usb going for compuhost after downloading asio4all,i'm using 64 bit windows 7
Thank you all for the help
PostPosted: Fri Jan 29, 2010 10:56 am
BBE to main inserts.
Compressor to the mic channel inserts.
PostPosted: Fri Jan 29, 2010 1:07 pm
Check that you are using a balanced XLR to TRS cable from your mixer to your amplifier. A TRS cable will have two black circles around the 1/4" jack, separating the metal surface into three conductors called "tip," "ring," and "sleeve." If it only has one black circle, it is a TS connector, which is unbalanced. Balanced signaling cables are more resistant to electrical noise.
If your cable is not the XLR to TRS kind then replace it with a new/different cable.
Also, make sure all your equipment is plugged into a common power source. It should all go into a power strip, rack-mount power distributor, or similar device; and that should go into one wall outlet. (This changes if you get bigger, but for karaoke, this is the most "fool-proof" way.)
Jeff Wheeler, moonlight DJ/KJ
Users browsing this forum: No registered users and 1736 guests
