KARAOKE SCENE MAGAZINE ONLINE! - Do I need a mixer with two Aux Send outputs? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 5:55 pm
PostPosted: Tue Jan 26, 2010 9:54 am
Hi,
I am looking to buy a mixer and an effect processor for home Karaoke. The effect processor I am looking at is TC M350 or Lexicon MX-200. Both of them has two audio input - L and R. But most of the compact mixer such as Mackie 802-VLZ3 only has one Aux Send. Based on the effect processor manual, I can just connect the mixer Aux Send to the L audio input. (effect Return is always stereo, no problem there)
More expensive ones like Mackie 1402-VLZ3 has two Aux Send. Then I can connect to both L and R audio input of the effect processor. I am wondering for Karaoke purpose, do I really need a mixer with two Aux Send to fully utilize the potential of the effect processor?
Thanks in advance.
PostPosted: Tue Jan 26, 2010 10:21 am
Most mixers that are suitable for karaoke have two. One is usually marked FX, and is post-fader (or selected to that by default). The other is usually called AUX, and is pre-fader, such as makes sense for a monitor wedge.
If you are going to eschew the monitor, the Yamaha MG82CX is a decent choice. BUt better is a Yamaha MG124CX, which has two AUX and compression.
At the low end, the Alesis Multimix 8 USB has two AUX. I own one, but don't like it whole bunches. I prefer the Yamahas.
PostPosted: Tue Jan 26, 2010 12:04 pm
So I should connect FX, not AUX, to the effect processor like TC M350, correct?
PostPosted: Tue Jan 26, 2010 12:17 pm
If it has an FX send, yes. I am not sure the VLZ3 does.
PostPosted: Tue Jan 26, 2010 12:23 pm
Actually 802-VLZ3 only has one send, but it is called AUX send. Will it work?
PostPosted: Tue Jan 26, 2010 12:25 pm
A question about Yamaha MG124CX, should I connect both of its AUX send to the effect processor? Does it matter whether I connect AUX1 to Left and AUX2 to Right, or vice versa?
PostPosted: Tue Jan 26, 2010 12:45 pm
Yes that will work.
PostPosted: Tue Jan 26, 2010 12:46 pm
Yes the Aux send will work, send it to the mono input on the effects processor & run both left & right channels back to the mixer, I prefer to run them to individual channels personally over the effects returns.
PostPosted: Tue Jan 26, 2010 12:47 pm
No, you just use the Aux 2 which is the post-fader send marked FX. It goes to the Left/Mono input of the MX200, and I bring the left/mono out back into a channel instead of an AUX return. That allows me to EQ and use a fader on the returned signal.
PostPosted: Tue Jan 26, 2010 12:57 pm
You can, it won't make a huge difference to use both inputs in most situations.
PostPosted: Tue Jan 26, 2010 1:30 pm
There's no need to send a left and right signal to the effects processor unless you're specifically doing some wierd stuff with panning. Remember your mic channels are a mono signal so unless you have some panned to one side and others panned to the other side there's no need for a stereo send. Just use a post-fade aux (or efx - really the same thing) send into the mono input of the processor and bring the stereo return back in on a stereo channel or in your console's stereo return. Like Lon, I prefer the former method (bringing it in on a stereo channel) as it's easier to use a fader than a knob and it allows you to EQ the effects as well.
DJ Tony
PostPosted: Tue Jan 26, 2010 1:38 pm
If I bring the stereo return back in on a stereo channel, how do I prevent the feedback? I am afraid it is going to be sent to the AUX send and to the processor again. Should I turn the AUX knob on this channel all the way down?
PostPosted: Tue Jan 26, 2010 1:52 pm
If you send it back to a channel, you don't turn the Aux send on that channel up - so yes make sure it is completely turned down, only turn up the Aux on the mic channels.
PostPosted: Tue Jan 26, 2010 5:22 pm
I know the MX200 has a mono-input, stereo-output mode; and the TC unit should as well. If not, you can still use a single AUX output to supply both processor inputs by using a splitter cable like the YFMM part at this link:
http://www.audiopile.net/products/Mic_I ... heet.shtml
The MX200 is a nice unit.
Jeff Wheeler, moonlight DJ/KJ
PostPosted: Tue Jan 26, 2010 5:56 pm
Been Liked: 34 times
And most important about the MX200, it has a USB connection which allows you to use the unit as a VST plugin with your studio software, that alone makes it worth buying it :wink:
Users browsing this forum: No registered users and 1662 guests
