KARAOKE SCENE MAGAZINE ONLINE! - Sound Distortion Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sun Oct 25, 2026 1:46 pm
 Post subject: Sound Distortion
PostPosted: Mon May 03, 2004 7:05 am
Hi,
I am very new here and would like to congratulate you all on a great site. I have been reading other members posts for a while and hope someone can help me with a few problems. I have a home setup that we use at family bbq's. I have provided some info that may be of some assistance.
2 x Peavey SP 5xt Speakers
1 x JVC Tripple Tray CDG Player
1 x Bellani Mosfet Amp
8 ohms 165 watt per channel
4 ohms 268 watts per channel
Bridged 8 ohms 504 watts
2 x Sennheiser E835 Microphones
I am getting major distortion out of the speakers during some (especially the latest) audio cd's when they are played. This also happens to many of the cdg's that I have. The songs produced by Nutech seem to be much better than the All Hits and Legends cdg's. Sometimes even when the music is not playing the voice through the mic is distorted. :twisted: Then within the same breath I will play another song and the singer/mic and music will be really clear and sound fine. I don't understand much about the gear I have, as we only wanted a home setup that wasn't expensive and that could handle some happy drunks. I am not technically minded and would appreciate any help as it sounds really terrible.....
Alisa :lol:
PostPosted: Mon May 03, 2004 9:19 am
Bad speaker wire.
PostPosted: Mon May 03, 2004 11:22 am
Since I'm not familiar with your Bellani amp I did some quick searching, if I'm reading correctly the Bellani is a pre amp which is feeding another amp? If you're plugging your JVC player into the pre amp you are probably overdriving the amp. If there is another input on the amp, try using that and bypass the pre amp.
PostPosted: Wed May 05, 2004 3:38 am
Thanks for your suggestions guys.
Will go and give them a try. :P
Alisa
G'day From Downunder
PostPosted: Fri May 07, 2004 5:44 am
I'm not familiar with that amp either. Does it have mic inputs? If so, are you plugging your mics directly into them or into the mic jacks on the front of the JVC player. If you're going into the JVC player jacks, it will sound terrible. Mine always did. When I plugged them directly in an amp with mic inputs, everything cleaned up quite nicely. Just my .02 worth.
PostPosted: Mon May 10, 2004 1:36 pm
Since Nutech is "usually" recorded at lower level, sounds like you shoud turn the input of your player down and your mains up
The opinions of Sammy do not necessarily reflect the views of the Karaoke Scene Magazine - Advice is given with a sence of humor and should be taken accordingly - If you have problems setting the clock on your VCR - You've come to the right place
PostPosted: Tue Jun 15, 2004 8:39 am
Problem solved. It seems as though the Bellani amp was a pre amp I have since bought a new amp and everything is aok. Thanks to everyone for their help. :D
Users browsing this forum: No registered users and 3151 guests
