[ 20 posts ] |
armando
Posted: Sat Nov 14, 2009 7:35 am |
Joined: Tue Nov 03, 2009 5:00 pm Posts: 19 Been Liked: 0 time
what is a good computer that will do a good job
jdmeister
Posted: Sat Nov 14, 2009 8:15 am |
Joined: Sun Mar 24, 2002 4:12 pm Posts: 7731 Songs: 1 Location: Hollyweird, Ca. Been Liked: 1096 times
Laptop with s-video out..
Some newer ones have HDMI out, tougher to use..
lyquiddye
Posted: Sat Nov 14, 2009 8:56 am |
You can still find a few new computers with s-video out.
Dell Insirion 1525
There are handful of Toshiba models.
letitrip
Posted: Sat Nov 14, 2009 9:24 am |
Well this is a tough question to answer since you've given really no information. Most Windows laptops on the market today or even in the last 5 years could run Karaoke software. What do you plan to use for the lyrics monitor? A TV? If so what kind of inputs does it have? If it doesn't have s-Video input, then an s-Video output on the laptop does you no good. IF the TV needs RCA then you either will need a converter or a laptop with RCA output (not very common anymore). If your TV only has an RF (Coax) input, you'll need an RF modulator. If you use an LCD Computer monitor, then as long as the laptop has a VGA out you'll be fine.
Here's what I'd look for assuming you're buying new. Get a Windows laptop with a minimum of 1GB RAM, preferably 2GB. Personally I'd recommend using an external drive to store your tracks on so the internal HD capacity won't be much of a factor since all laptops seem to be coming with 80GB drives or larger. Other than that, find the features you want if you plan to use it for anything else.
_________________ DJ Tony
RLC
Posted: Sat Nov 14, 2009 10:19 am |
letitrip @ Sat Nov 14, 2009 11:24 am wrote: If it doesn't have s-Video input, then an s-Video output on the laptop does you no good.
Not really true, if the laptop has s-video out and the tv doesn't have s-video in then all you would need is a RF modulator (less than $20) that has s-video in and both coax and rca outs.
S-video out from the laptop and a RF Modulator as described above would cover most all bases as far as hooking up to TVs.
letitrip
Posted: Sat Nov 14, 2009 11:45 am |
RLC @ Sat Nov 14, 2009 12:19 pm wrote: letitrip @ Sat Nov 14, 2009 11:24 am wrote: If it doesn't have s-Video input, then an s-Video output on the laptop does you no good. Not really true, if the laptop has s-video out and the tv doesn't have s-video in then all you would need is a RF modulator (less than $20) that has s-video in and both coax and rca outs. S-video out from the laptop and a RF Modulator as described above would cover most all bases as far as hooking up to TVs.
 Agreed, did you see the rest of my post where I mentioned converters and RF modulators?  There are options to convert either the S-Video out or the VGA out to all sorts of other formats, most are pretty inexpensive.
Posted: Sat Nov 14, 2009 11:47 am |
There are even HDMI to S-Video converters, although pricy!
armando
Posted: Sun Nov 15, 2009 6:00 am |
Again thanks to all, i will be using it primarly for the software and connecting to a mixer and using a flat panel monitor .
jdmeister
Posted: Sun Nov 15, 2009 6:22 am |
Computer with flat panel (LCD) monitor is my main party setup..
(I don't need much at a small party)
The same will work in a small club, but the TV connection allows TVs around the room to be used.
The TV signal splits easier..
The s-video to RCA dongle is $5.00 at the electronics parts store..
and $20.00 @ a big box store.
armando
Posted: Sun Nov 15, 2009 6:35 am |
many thanks again i am not the computer guru so i have no clue .
armando
Posted: Sun Nov 15, 2009 7:46 am |
so would a vga output on the laptop and a vga input on the moniter work?
jdmeister
Posted: Sun Nov 15, 2009 9:44 am |
Yes.. That's what I use..
Today, Office Depot has a MSI laptop for $319.99
15.6 screen, 3 gig ram, 160 gig HD Windows 7
Grab it..
Micky
Posted: Sun Nov 15, 2009 9:01 pm |
armando @ Sun Nov 15, 2009 10:46 am wrote: so would a vga output on the laptop and a vga input on the moniter work?
Yes, and it's probably the best option
4003fg
Posted: Mon Nov 16, 2009 10:38 am |
| Major Poster |
Joined: Mon Mar 03, 2008 11:40 am Posts: 55 Been Liked: 0 time
I love my HP DV2000 laptop, screen's kinda small, but it runs like a champ.
armando
Posted: Sun Dec 13, 2009 6:36 pm |
well i decided to go with a gateway t6600 core duo.
jdmeister
Posted: Mon Dec 14, 2009 5:53 am |
The best $599.00 you can spend.. (@ Best Buy)
armando
Posted: Mon Dec 14, 2009 8:50 pm |
Thanks JD, one of the guys at work said this would do the job.
c. staley
Posted: Fri Dec 18, 2009 9:42 am |
| Extreme Poster |
Joined: Thu Jun 06, 2002 7:26 am Posts: 4839 Location: In your head rent-free Been Liked: 583 times
lyquiddye @ Sat Nov 14, 2009 2:56 pm wrote: You can still find a few new computers with s-video out.
Dell Insirion 1525
Just don't expect the Dell with both the HD and Svideo outs to work properly. A friend of mine has one and it will NOT address the Svideo out at all... after many hours on the phone with dell and tech support, even Dell gave up...
jdmeister
Posted: Fri Dec 18, 2009 3:07 pm |
Sony makes some good laptops too..
The few I've bought had dedicated video ram, freeing up main memory..
+ firewire in/out and composite out. (TV)
If the system is older, (With S3 Video) the Windows update kills the TV out..
ripman8
Posted: Tue Dec 29, 2009 7:05 am |
jdmeister @ Mon Dec 14, 2009 7:53 am wrote: The best $599.00 you can spend.. (@ Best Buy)
I wouldn't buy a floppy from those crooks let alone spend hundreds. Worst service after the sale in the civilized world!
I have 2 laptops, spend just about $500 for the two of them combined (ebay). One is toshiba and one is dell. The Toshiba is my show computer. It is 17". The 15" dell is my back up. I don't use them for the internet other than to download compuhost. Never had a problem running my show with the toshiba, I have the dell hooked up at home to my home set up and no problems with it. External hard drives are very cheap nowadays. A 500 GB EHD will hold about 50,000 karaoke tracks and 50,000 regular tracks or more. This is the route I have chosen, some buy a big drive in the computer and put their music there. My little 160 gb WD Passport takes up next to no room in my set up.
[ 20 posts ] |
Users browsing this forum: No registered users and 1727 guests |
