KARAOKE SCENE MAGAZINE ONLINE! - Shure PG288/PG58 Dual Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 10:28 pm
 Post subject: Shure PG288/PG58 Dual
PostPosted: Thu Feb 04, 2010 6:16 am
Thinking about adding this wireless system? Any Thoughts? Cheapest Price;
http://bestmusic.mybisi.com/product/0/S ... 02044.html
PostPosted: Thu Feb 04, 2010 6:29 am
Been Liked: 15 times
Very good. It's so good I bet they don't have any in stock. Everyone else is selling the same thing for $550 and up. Give them a call and if they say they have it in stock, place the order over the phone with a credit card(don't use a debit card). Good luck, let us know how it goes.
PostPosted: Thu Feb 04, 2010 8:59 am
That's an amazing price, I would jump on that right away. I bought two of those dual sets from American Musical last year for $489 a pop on an open-box special. That's a great price for a good set of mics.
The mics themselves are pretty nice, I've been very happy with them. I was a little concerned about their range since they have the integrated internal antennae and I was planning to rack mount them (you have to buy a separate shelf from Shure to do so) but they've done well. Audio wise, the PG58 is pretty close to the SM58 with some subtle differences. The biggest difference is in handling noise, the PG58's are definitely not as well isolated so as people jostle the mic from hand to hand or whatever, you will get some noise from it. Not a problem when singing but definitely noticeable if there's nothing else going on at the time. They do have the same proximity effect that the SM58 is known for which is great for adding warmth but you have to know how to manage it if you get a low singer who knows how to get right on the mic (just use the EQ to pull out a little around 250Hz to compensate if needed).
The only thing I actually don't like about them is that they use 9V batteries instead of AA's like all the other current Shure kits. An alkaline 9V will last a good 8 hours, I get 2 shows or better (depending on how much it is used) out of each new battery. I tried some rechargeable 9V's, they were good for a while but now don't even last through an entire show many times.
There is an adjustable level control on the back of the receiver for each mic. I had to adjust mine a little bit, the signal was awful hot with the factory config. Very easy to adjust, handy as hell to have that ability. There's no sync feature between the receiver and Mic for setting the channel, but it is an easy process to set them and it's hidden in the battery compartment of the transmitter so you don't have to worry about anyone accidentally or intentionally messing with it.
I've used the PG288 kits I have in a few live band situations where I was in a pinch. I was running FOH for a band that had a lead and 3 backup singers and given the nature of the stage, running cables to wired mics would have been a real pain in the butt. I gave the lead my SLX-Beta58 and the backups each used one of the PG58's. The results were good, I was really happy with how the mics performed.
Assuming you're using them for Karaoke, I would recommend somehow marking them so you know which is which. I bought the WA615M ID rings from Shure for this purpose and they work out pretty nice (although they do make it a little tougher to get the mics in and out of the clips if you don't know how to do it right):
http://store.shure.com/store/shure/en_U ... .105001600
Colored electrical tape would work too.
DJ Tony
PostPosted: Thu Feb 04, 2010 9:59 am
Nice review.
I went for the SM-58s instead, as I hate handling noise. I was also able to pick them up used for ~250 a copy (of course only one for that price). In addition, the PGX4 gives you the ability to add transmitters with different characteristics. I have the wireless lavalier pack for speakers, and can add the headset mic to that as well.
Does the 288 receiver work with PGX1/2 transmitters?
PostPosted: Thu Feb 04, 2010 10:41 am
mcky, as far as I know, the Performance Gear (PG) series receivers do not work with the PGX transmitters. I think the problem you'd have is that they don't operate in the same frequency bands. The PG series systems are available in the H7, K7 and M7 bands whereas the PGX are available in the H6, J6, L5, P6, R1 and T1 bands.
The PG series does have the PG1 body pack which works with instruments or lav mics, just like the PGX1. I've actually been considering purchasing one or two so I'd have additional instrument packs (I Have one SLX1 today).
DJ Tony
PostPosted: Fri Feb 05, 2010 4:35 pm
I would ask what frequency they operate on. They may be 700mhz+ and useless in June.
The M7 version of this microphone is the most versitile. It has fequencies in the 600mhz range.
They do eat 9v batteries. I moved to SLX that us AA. I get 2 or 3 weeks on a set of AA vs getting 2 shows on a 9V.
PostPosted: Tue Feb 16, 2010 11:16 am
Order cancelled today money sent back to Pay Pal
PostPosted: Fri Feb 19, 2010 12:35 pm
I'm guessing they were old 700Mhz??
Users browsing this forum: No registered users and 1862 guests
