KARAOKE SCENE MAGAZINE ONLINE! - Help Me Hook It All Up? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 8:01 pm
 Post subject: Help Me Hook It All Up?
PostPosted: Wed Dec 23, 2009 1:45 pm
Got my new stuff today and am going to try and get everything hooked up,i might could figure it all out but thought it best to check with pros here for best way to ensure optimal sound quality without risk of blowing something up!
Here is my list...
BBE 882I SONIC MAXIMIZER
Yamaha P5000S Dual Channel Power Amp
Allen & Heath ZED-12FX USB Mixer
dbx 266XL Compressor/Gate (Do i even need it with BBE?)
2 Yamaha BR15 15" (Hoping these will work with the amp,without blowing them out)
Karaoke media is on my laptop using Compuhost
M-Audio Fast Track Pro Mobile USB Audio/MIDI Interface (Going to Eliminate this and use the Zed USB Interface)
PostPosted: Wed Dec 23, 2009 2:23 pm
Use an insert cable for the BBE to the Main Insert jacks on the mixer. You will need 2 for both L & R channels. Like these:
http://www.bhphotovideo.com/c/product/1 ... le_to.html
Plug the 1/4" into the mixer & the XLR into the input/output on each channel of the BBE. The BBE, don't overuse it. This is a common mistake people make which can yield in a harshness in the high end. It's not really designed to be an eq, it's frequency aligner to help project the signal to the speakers better in a live situation.
Take the Main out on the mixer & run to the inputs on the amp.
The speakers are rated at 400 watts program, the amp will push 525 watts into each speaker, a little more than required but as long as you aren't puching them into the stratosphere volume wise, you should be fine.
I would use the 266XL on the mics only (don't confuse it with the BBE - totally different processor), again you will need an insert cable for this. There are only two channels on the compressor so you will only be able to compress 2 mics. 2 cables like these:
http://www.zzounds.com/item--HOSSTP20
Plug the single end into the mic channel insert jack & the 'tip' plug to the input on the dbx, the 'ring' plug to the output.
I would set the compressor settings to a basic starting point
Threshold - -10
Overeasy button pushed in
Ratio - can vary anywhere from 2:1-4:1
Between the attack & release is an auto button - push this in. For different singers it will automatically adjust the attack & release.
Output gain - start at 0 and adjust accordingly. You want the compressed signal to be about the same as the non compressed signal volume wise when the compressor is bypassed.
Don't worry about the expander/gate section, just leave those fully counter clockwise.
If you use the USB interface on the mixer, then you won't need the Fast Tracks, however you may find the external sounds better - try both ways.
USB interface, plug the USB into the computer to the interface, the RCA outputs just plugs into the stereo channels of the mixer.
PostPosted: Wed Dec 23, 2009 3:55 pm
Thank you very much Lonman
Users browsing this forum: No registered users and 1827 guests
