KARAOKE SCENE MAGAZINE ONLINE! - using 1 JBL EON G2 Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 8:01 pm
 Post subject: using 1 JBL EON G2
PostPosted: Fri Dec 11, 2009 9:06 am
Im playing a very small venue tonight and want (need) to only use one JBL eon G2 speaker. How would I set it up on my mixer to get left and right channels playing through speaker? I was thinking left main out to speaker then use two channels on board to control left and right. THanks :D
 Post subject: Re: using 1 JBL EON G2
PostPosted: Fri Dec 11, 2009 9:45 am
Might be helpful to know which mixer you have....
PostPosted: Fri Dec 11, 2009 10:17 am
Sorry, Mackie cfx12 mixer
PostPosted: Fri Dec 11, 2009 10:56 am
Really easy actually. On the CFX12, everything has to go through the Sub Groups. Leave everything on your board setup the way you would usually have it (don't change the panning of channels or anything). Go to the sub-group channels that you're using (the blue faders labelled 1-4) and use the assign buttons to assign them each to LEFT only (Under normal circumstances they're probably set so that 1 & 3 are assigned LEFT and 2&4 assigned to right). By assigning them all to left only, all your output, whether panned right or left, will be sent to the left main out. Now just connect your EON to the Left main out on the board and you're all set. Use the rest of the board the way you normally would as if you were running in stereo.
DJ Tony
PostPosted: Fri Dec 11, 2009 11:59 am
Thanks! :D
PostPosted: Fri Dec 11, 2009 12:13 pm
Unless you are using the stereo channels, then you have to run those channels panned straight up, running through a separate subgroup (I always ran mics on 1-2 & music on 3-4), then in the sub group for the music channels, push BOTH 3 & 4 left button (you will be using both 3-4 sub faders) otherwise you won't be getting the full recorded signal.
PostPosted: Fri Dec 11, 2009 12:29 pm
I would have music in 11/12 stereo channel. So run 11/12 with 3&4 button pushed down and left button pushed down on 3 & 4 sliders?
PostPosted: Fri Dec 11, 2009 1:15 pm
Correct!
Users browsing this forum: No registered users and 1826 guests
