KARAOKE SCENE MAGAZINE ONLINE! - What's this? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 9:17 pm
 Post subject: What's this?
PostPosted: Sun Nov 22, 2009 11:53 am
I have a Mackie 808M and it appears my dampening knob has taken on a mind of it's own. I was getting a horrible echo from my system and discovered my dampening knob's adjustments are off. I used to keep the knob straight up which is basically the normal position. The settings go from zero to ten. Now I've found the position to have slid to the left quite a bit. For instance what used to be the 5 position is now the 3 position. What the heck? How do I fix this.
It's not a huge problem because I know where to set it to get the right sound, but I'd like my equipment to be working correctly. Plus I don't want it getting worse.
 Post subject: Re: What's this?
PostPosted: Sun Nov 22, 2009 2:30 pm
when you turn the knob all the way counter clockwise when it reaches the end does it point to zero? and if you turn it all the way clockwise does it point to 10?
If not I'm thinking the knob has slipped on the shaft.
If it does listen to some music and turn it from zero to 10 slowly and see if you can see a difference all the way up. If you don't get an equal increase it could be that your pot shorted out internally.
If all works fine then I'll have to rethink.
PostPosted: Sun Nov 22, 2009 3:58 pm
Her knobs may go to 11.. :angel:
PostPosted: Sun Nov 22, 2009 4:28 pm
Images: 8
Been Liked: 47 times
Perhaps somebody monkey'd with it? :D
♥ Laugh your heart out, dance in the rain. Cherish the memories, ignore the pain. Love and learn, forget and forgive. Because you only have one life to live. ♥
PostPosted: Sun Nov 22, 2009 8:48 pm
Ahh the wonders of cheap pots. Honestly Babs, this is not all that uncommon with inexpensive boards. Essentially each knob is a potentiometer (pot). What that means in English is its a device that as you turn it creates a variable amount of electrical resistance usually ranging from no resistance to some very high amount. That resistance prevents a certain amount of voltage from going through which is what gives you volume or other level controls. As these pots wear out, a few things can happen. They can develop dead spots where there is no electrical connection at all (infinite resistance) or, as the case with what you're experiencing now, the degree at which the resistance increases or decreases as you turn the knob changes over time.
So now back to total English, what it sounds like you're experiencing is the slow deterioration of that particular component. Nothing you can really do about it, Mackie would charge a fortune to fix it. There is a guy up here that I know who does some board level repair on Mackie equipment however, it's probably not worth the cost. Just keep using it accounting for the shift in position and you'll be fine.
DJ Tony
PostPosted: Mon Nov 23, 2009 3:47 pm
Been Liked: 8 times
with a little help mine do too
PostPosted: Mon Nov 23, 2009 6:20 pm
:mrgreen: :angel:
PostPosted: Mon Nov 23, 2009 8:52 pm
Been Liked: 25 times
11? as in one louder? WOW! So jealous.
I have a Yamaha MG124CX (still sealed in it's box) which was passed on to me by a bandmate. After mobile gigging it 3 times I had to admit that I'm not confident with the mixer. Yes it works as it should but I doubt it would last long so I decided to upgrade. I bought the Soundcraft MFXi8. Everything is just night and day on the build quality. All in all I have three mobile mixers... Yamaha MG124CX, Edirol M-10DX and Soundcraft MFXi8. I will keep the Soundcraft and Edirol... the Yamaha will be donated to an elementary school nearby :)
PostPosted: Tue Nov 24, 2009 6:59 am
Perhaps the Yamaha might work better if it was not still sealed in it's box! :roll:
PostPosted: Tue Nov 24, 2009 7:57 am
I was hoping you were smarter than that :|
PostPosted: Tue Nov 24, 2009 2:22 pm
So what you are saying is your knobs use to stand straight up and now they slid a little to the left ? :rotflmao: :rotflmao:
How do you fix this ???? two words Victoria Secrets :D
PostPosted: Fri Nov 27, 2009 4:08 pm
LOL
I think Letitrip figured out the problem, thank you.
PostPosted: Mon Nov 30, 2009 6:27 pm
:angel:
PostPosted: Tue Dec 01, 2009 4:48 am
Well, It looks like this post is going South, but I guess everything does after awhile. :wink:
Users browsing this forum: No registered users and 1746 guests
