| Mixing/Speaker Question https://ksmo.us/forums/viewtopic.php?f=1&t=18203 |
| Author: | Kevinper [ Wed Nov 04, 2009 4:32 pm ] |
| Post subject: | Mixing/Speaker Question |
Let me preface this with the fact that the bar owner turned the left speaker to face a wall instead of the bar because it was too loud for him sometimes. We have a Yamaha MG82cx and at our halloween gig, I went over by the left speaker and the voice was overpowering the music although the balance's were set to center. Could this be a problem with the speaker itself? It is an old Ross speaker. I have a hard time believing it may be the mixer. Thanks, Kevin |
| Author: | Lonman [ Wed Nov 04, 2009 4:37 pm ] |
| Post subject: | Re: Mixing/Speaker Question |
If it was the vocals overpowering it would seem that there is something possibly wrong with the mixer outputs (although probably not if you were getting full volume on vocals), dirty pots/fader shorting out one channel on the music, possibly a bad cord on the music between the player & mixer. Check all connections, reverse the cords on the music right to left & vice verse. Check all pots & faders on the mixer channel - again could have a dirty section that is preventing the signal going to the main output. |
| Author: | Kevinper [ Wed Nov 04, 2009 5:22 pm ] |
I'll give that a try, thanks. |
| Author: | letitrip [ Wed Nov 04, 2009 7:49 pm ] |
I'm assuming the speaker is a 2-way (woofer + horn). It could be a problem with the speaker's internal crossover network that perhaps the woofer isn't getting the full power it should. I think more likely is that there's a connection issue somewhere as Lon described. |
| Author: | Kevinper [ Wed Nov 04, 2009 9:46 pm ] |
I'll be back at the bar tomorrow night so I will play with it. It's a pain the way he moved it. I can really only hear the right side from where I'm at so I have to keep walking over to it after making an adjustment. It is a two-way which did have a connection problem a few weeks ago. The jack was loose but I took it down and fixed that problem. |
| Author: | Kevinper [ Fri Nov 06, 2009 4:35 pm ] |
Well it must have been a loose connection last week because this week it was fine. Thanks for your help! |
