KARAOKE SCENE MAGAZINE ONLINE! - Mixing/Speaker Question Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 10:27 pm
 Post subject: Mixing/Speaker Question
PostPosted: Wed Nov 04, 2009 4:32 pm
Let me preface this with the fact that the bar owner turned the left speaker to face a wall instead of the bar because it was too loud for him sometimes.
We have a Yamaha MG82cx and at our halloween gig, I went over by the left speaker and the voice was overpowering the music although the balance's were set to center.
Could this be a problem with the speaker itself? It is an old Ross speaker. I have a hard time believing it may be the mixer.
Thanks,
Kevin
PostPosted: Wed Nov 04, 2009 4:37 pm
If it was the vocals overpowering it would seem that there is something possibly wrong with the mixer outputs (although probably not if you were getting full volume on vocals), dirty pots/fader shorting out one channel on the music, possibly a bad cord on the music between the player & mixer. Check all connections, reverse the cords on the music right to left & vice verse. Check all pots & faders on the mixer channel - again could have a dirty section that is preventing the signal going to the main output.
PostPosted: Wed Nov 04, 2009 5:22 pm
I'll give that a try, thanks.
Kevin
PostPosted: Wed Nov 04, 2009 7:49 pm
I'm assuming the speaker is a 2-way (woofer + horn). It could be a problem with the speaker's internal crossover network that perhaps the woofer isn't getting the full power it should. I think more likely is that there's a connection issue somewhere as Lon described.
DJ Tony
PostPosted: Wed Nov 04, 2009 9:46 pm
I'll be back at the bar tomorrow night so I will play with it. It's a pain the way he moved it. I can really only hear the right side from where I'm at so I have to keep walking over to it after making an adjustment.
It is a two-way which did have a connection problem a few weeks ago. The jack was loose but I took it down and fixed that problem.
Kevin
PostPosted: Fri Nov 06, 2009 4:35 pm
Well it must have been a loose connection last week because this week it was fine.
Thanks for your help!
Kevin
Users browsing this forum: No registered users and 1848 guests
