KARAOKE SCENE MAGAZINE ONLINE! - Question on (daisy chaining) Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 11:57 pm
PostPosted: Wed Sep 23, 2009 7:57 am
Been Liked: 20 times
I just purchased 2 JBL EON10 G2's, so I can work small venues (corner bars, etc), I already have the EON15 G2's that I've been using. If I wanted to do a BIG venue, and daisy chain the 10's with the 15's, would that deminish my 15's, or would that mean that as long as I have them set the same that the signal would push them at the same level of their capacity? I hope my question makes sense, if not, let me know. Also, if I were going to use 1 of them as a monitor, would you suggest hooking it to the earphone jack, or the monitor out? I'm sure I will have more questions, but this is enough to start with.
Sidenote: My mixer is a Mackie Profx 12. I am computer based.
Srnitynow
PostPosted: Wed Sep 23, 2009 8:13 am
I have the same setup and use the 10 for fill, piping sound into another area or room and the main purpose is a monitor all daisy chaining. . Sometimes I use the Mon send. Those lil guys will blow your mind everytime you listen to them.
PostPosted: Wed Sep 23, 2009 9:45 am
Srnitynow
You could do that. I wouldn't try running in stereo, using the 15's on one channel & the 10's maybe in the back of the room on a separate channel so you can control that section individually.
For monitors, use the monitor out.
PostPosted: Wed Sep 23, 2009 9:47 am
You'll be fine daisy-chaining the EONs. One huge advantage of powered speakers is not having to worry about impedance matching multiple speaker setups. I would probably do it pairs of 15 & 10 on each channel
I'd use the monitor out. The whole idea of a monitor mix is that it's an entirely separate mix tailored to what the performer needs or wants to hear. This usually is completely different from what sounds good through the main house mix - different EQ, different FX levels, and different volume levels for the mix elements, all tailored to help the performer give the best they can.
Dave's not here.
PostPosted: Wed Sep 23, 2009 10:42 am
Remember as much as 6DB at bass freqs can be gained from putting a speaker in a corner. Speakers on the opposite end can be "inconspicus" in corners. Placement can be critical.
placement
PostPosted: Thu Sep 24, 2009 12:26 am
placement
Did you read the part about the use of one or two subs? :angel:
Users browsing this forum: KarenB and 1995 guests
