KARAOKE SCENE MAGAZINE ONLINE! - SPEAKER QUESTION ???????? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sat Oct 24, 2026 10:01 pm
PostPosted: Fri Apr 09, 2004 3:26 pm
:?: Hello my question is about speakers , I want to buy a set or speakers that can be used for karaoke as well as music DJ ing .can you give some brands i can look for ? I heard karaoke speakers differ from DJ MUSIC speakers so i want to make sure i can offer the best sound for both venues without buying seperate speaker sets. thank you
PostPosted: Fri Apr 09, 2004 6:20 pm
Passive:
Mackie
Peavey
JBL
Carvin
Cerwin Vega
Yamaha
Active:
Mackie
Carvin
B-52
ISP Technologies
I'll be using powered ISP Tripower 900 mains and powered B-52 ACT 18 Subs. I'm thinking of adding a pair of Carvin powered 1584A's or 1588A's down the road somewhere.
PostPosted: Fri Apr 09, 2004 6:21 pm
Don't forget Yorkville.
PostPosted: Fri Apr 09, 2004 6:51 pm
I know this may sound stupid :cry: But what do you mean by passive and active referring to speakers ?
PostPosted: Fri Apr 09, 2004 10:52 pm
Active speakers have the amps built in whereas with passive speakers you require an amp.
Active - plug power cord into an electrical outlet and plug in sound cable from your non-powered mixing board.
Passive - Plug sound cable from board into the amp and then sound wires to the speakers. Amp plugs into the electrical outlet.
You will get various opinions on each setup. I prefer powered and use a Yorkville system (they also make fabulous passive systems). Amps are made for the speakers and you get a great crisp sound. But the biggest advantage is that if one speaker decides to breakdown you can continue on with the other speaker. Whereas, using a passive system, if the amp breaks down, shows over. Yes people say carry an extra amp but with builtin amps you save lugging around an extra amount of weight. Most active speakers weigh between 38lbs for Yorkville NX520s to 48 lbs for Mackie 450s.
We also use sub-woofers (bass bins) that are also powered.
PostPosted: Fri Apr 09, 2004 11:58 pm
:D Thank you !
PostPosted: Sat Apr 10, 2004 1:31 pm
B-52 SR15
B-52 SR 18's
Perfect setup for any indoor function
Users browsing this forum: No registered users and 3067 guests
