KARAOKE SCENE MAGAZINE ONLINE! - Trouble w/Top Tunes Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 12:37 am
 Post subject: Trouble w/Top Tunes
PostPosted: Sat Aug 29, 2009 7:54 am
I have about a dozen Top Tunes discs and although I have gotten a 3 to rip others I have tried stop the ripping process at about 6% on the firsdt song. I even pulled out my back-up copies that were burned when the disc was new and same thing. They play fine but having trioble ripping into compuhost. Any Tips?
 Post subject: Re: Trouble w/Top Tunes
PostPosted: Sat Aug 29, 2009 12:13 pm
We had this same problem with cerain TT and some All Star disks as well. Tried a coule different ripping utilities. Finally bought microstudio for these and problem solved. Its a good utility for ripping any disks that are scratched or have artifacts on playback. Because we did not b uy whole suite we rip with microstudio and then burn back to blank cd in cdg format. Compuhost will then rip. Although now the MTU Songverter program will convert kma to zip files without re ripping. There may be other otions but this saved us when we first converted out library seveal years ago.
PostPosted: Sat Aug 29, 2009 2:19 pm
Thanks, I was hoping to find a cure w/o buying anything else. That seems to cure everything but my bank acct.
PostPosted: Sun Aug 30, 2009 9:28 pm
Had the same problem with my 6 Top Tunes discs... I seemed it would take forever for the discs to rip.
I just set the drive I use for ripping to the MAX setting from the usual 4X speed I rip at, problem solved.
Hope this helps....
:D
Lito
"It's all about having FUN"
PostPosted: Mon Aug 31, 2009 9:57 am
Thanks, I'll try it.
PostPosted: Wed Sep 02, 2009 12:54 pm
How about paying just a teeny weeny bit more and buying PowerCDG Burner for around $30.
Rips everything AND one button back burn to discs- best I've ever seen...
PostPosted: Thu Sep 03, 2009 1:11 pm
Here's what you do buy a loaded Hard Drive with 40,0000 songs for $150 :D
But just COPY the MP3+g files you have the discs for
This saves you time from ripping anything else and since you're only using the files you have a disc for you're not a pirate :shock: :shock: :shock:
PostPosted: Sun Sep 13, 2009 2:29 pm
I took your advice on the 4x speed and it worked with a couple of disc's that didn't write the first time and it worked great. I have re-ripped a top tune disc yet but I am confident it will work, Thanks.
Users browsing this forum: KarenB and 2016 guests
