| Questions About Roxbox and Singer's Discs https://ksmo.us/forums/viewtopic.php?f=1&t=17549 |
| Author: | mrgadget01 [ Wed Aug 26, 2009 6:42 pm ] |
| Post subject: | Questions About Roxbox and Singer's Discs |
I'm using Roxbox and ran into a problem with using singer's discs. When you set up the new singer, the program assigns F: as the cd rom drive. My drive is d: and it locks up the system looking for the wrong drive. Is there a way to change the drive designation in the program or reroute F: to look at D: ?
Also, do the discs have to be zip files to be read?
| Author: | Catseyeview [ Fri Aug 28, 2009 7:27 am ] |
| Post subject: | Re: Questions About Roxbox and Singer's Discs |
Unless you have the winamp cd+g disc plugin whatever drive you're using won't play but 30 seconds of the song from disc. A more simple solution would be to rip the song from the customer's disc then delete when they're finished. If it's a regular you might consider purchasing the dl of that song so you won't need to continue going through that process. |
