KARAOKE SCENE MAGAZINE ONLINE! - how do i make cd+g files work on disc? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 2:54 am
PostPosted: Mon Aug 24, 2009 7:44 am
ive been using a numark kmx02 karaoke mixer for a few months now and i just decided to start useing the karaoke side of it. ive got a few cd+g files along with the mp3 files i burnt them to disc but the dics wouldnt play on my mixer i think it mite be because it wont play an ordanry mp3 anybody no how i can solve this problem ?
PostPosted: Mon Aug 24, 2009 10:36 am
When you Burn Karaoke tracks to a disc:
Your DRIVE must READ and WRITE cdg!
There's a good chance that your DRIVE doesn't WRITE .cdg!
Solution: Either purchase a DRIVE that supports cdg or use a software,
i.e. Power Karaoke Burner. It works with most DRIVES!
sw00000p
PostPosted: Mon Aug 24, 2009 11:19 am
Actually, it's more than that. If the system doesn't play mp3, then it will not ready mp3+g either. As previous poster said, you will need a CD writer that will support CD+G format. Then the mp3+g has to be converted to CD+G format to be written to the disc. There are several programs that will allow you to do that so if you search past posts, you will find plenty of recommendations.
One way to tell if the CD+G is supported or not, once you rip the disc and play it on the player, if the music plays but the words do not come up, then the CD+G is not supported.
Seize the day and SING!!!
PostPosted: Mon Aug 24, 2009 6:47 pm
If your cd writer has Disc-at-once, you will likely be able to record cdg's. If not you will need to grt one.
Kevin
Users browsing this forum: No registered users and 2169 guests
