| Compressor or No Compressor? https://ksmo.us/forums/viewtopic.php?f=1&t=17470 |
| Author: | karaokeking211 [ Tue Aug 18, 2009 7:57 am ] |
| Post subject: | Compressor or No Compressor? |
I have never used a compressor except for my finger on the slider when a screamer, or low singer gets up to sing. I am thinking of adding an outboard compressor but before I do I wanted to find out if it was worth doing. Is it worth it and if so can someone recommend a good one? I run 4 mics and would like to have compression for all 4. It is only for karaoke and we all know that a large number of people that sing at our shows don't know how to use a mic properly. |
| Author: | Lonman [ Tue Aug 18, 2009 9:01 am ] |
| Post subject: | Re: Compressor or No Compressor? |
I won't run vocals without a compressor. For 4 mics i'd opt for the dbx 1046 quad. Not going to get much better than that. Behringer does make one as well, I had one - then a week later got something that actually worked. |
| Author: | jeffsw6 [ Tue Aug 18, 2009 9:10 am ] |
I own two Behringer MDX4600s and an MDX2600 and they are basically fine for entry-level live sound such as bar bands and karaoke. ~$130ea MAP for the 4 channel MDX4600 IIRC. |
| Author: | TopherM [ Tue Aug 18, 2009 9:42 am ] |
I have never had a separate compressor unit that I could hook up to just the vocal channels, so I'm not an expert on that. There is compression on my DBX DriveRack unit, but it has to be applied to the entire mix, and it makes the music sound horrible, so I don't use that feature. What I DO use is the limit feature of my mixer for the vocal channels and another limit threshold on the DBX DriveRack just in case, which protects my system from screamers and any other pops, like dropped mics, that might hurt the system. That serves my needs nicely. |
| Author: | jeffsw6 [ Tue Aug 18, 2009 9:59 am ] |
What mixer do you have that includes a limiter on mic channels? Interesting feature! |
| Author: | Lonman [ Tue Aug 18, 2009 10:22 am ] |
TopherM @ Tue Aug 18, 2009 10:42 am wrote: I have never had a separate compressor unit that I could hook up to just the vocal channels, so I'm not an expert on that. There is compression on my DBX DriveRack unit, but it has to be applied to the entire mix, and it makes the music sound horrible, so I don't use that feature.
What I DO use is the limit feature of my mixer for the vocal channels and another limit threshold on the DBX DriveRack just in case, which protects my system from screamers and any other pops, like dropped mics, that might hurt the system. That serves my needs nicely. Too much compression on an entire mix will hurt the sound. I run a compressor on the final with just enough to barely light the lights. It can actually make a mix sound a little louder - more so in band situation, but can work with karaoke music as well. |
| Author: | jeffsw6 [ Tue Aug 18, 2009 11:21 am ] |
A multi-band compressor can be useful on a whole mix or recorded music. They can also sound like crap, depending on the program material and settings. The BBE Sonic Maximizer is an example of such a unit, and Behringer has an "Ultramizer" product both stand-alone and built into their DJ mixers. Personally, I don't like these. I have used the one in my DDM4000 enough to know it hurts as much as it helps. |
| Author: | karaokeking211 [ Tue Aug 18, 2009 4:01 pm ] |
jeffsw6 @ Tue Aug 18, 2009 1:21 pm wrote: A multi-band compressor can be useful on a whole mix or recorded music. They can also sound like crap, depending on the program material and settings. The BBE Sonic Maximizer is an example of such a unit, and Behringer has an "Ultramizer" product both stand-alone and built into their DJ mixers. Personally, I don't like these. I have used the one in my DDM4000 enough to know it hurts as much as it helps.
When you say you don't like these are you saying compressors in general? |
| Author: | jeffsw6 [ Tue Aug 18, 2009 4:50 pm ] |
Sorry, I mean I don't like multi-band compressors (Sonic Maximizer, Behringer Ultramizer, etc.) on the full mix or recorded material. It makes some things sound better, some things worse. |
| Author: | LondonLive [ Tue Aug 18, 2009 9:43 pm ] |
karaokeking211 @ Tue Aug 18, 2009 10:57 am wrote: I have never used a compressor except for my finger on the slider when a screamer, or low singer gets up to sing.
I am thinking of adding an outboard compressor but before I do I wanted to find out if it was worth doing. Is it worth it and if so can someone recommend a good one? I run 4 mics and would like to have compression for all 4. It is only for karaoke and we all know that a large number of people that sing at our shows don't know how to use a mic properly. Compression is a valuable tool if used properly, unfortunately the fast majority are set up improperly causing more harm than good. Unless you want to spend a lot of time learning how to use a compressor or plan on doing more than just Karaoke in the future I would suggest something along the line of the inexpensive but effective TC Electronics C300. They are about as close to "easy to use" and "fool proof" as you can get. In my opinion they are at least as good as the DBX 266XL. Do a search and you can find a lot of good reviews on this unit. If you need four channels, buy two, a pair will still be only around $260.00. Are there better compressors? sure, do you need a better compressor for Karaoke? No, I don't think so. |
| Author: | LondonLive [ Tue Aug 18, 2009 9:59 pm ] |
jeffsw6 @ Tue Aug 18, 2009 2:21 pm wrote: A multi-band compressor can be useful on a whole mix or recorded music. They can also sound like crap, depending on the program material and settings. The BBE Sonic Maximizer is an example of such a unit, and Behringer has an "Ultramizer" product both stand-alone and built into their DJ mixers. Personally, I don't like these. I have used the one in my DDM4000 enough to know it hurts as much as it helps.
To me the multi band compressor is one of the most useful tools in my arsenal, although certainly not essential for Karaoke IMO it is still one of the best inventions since sliced bread when it comes to fine tuning a PA. Ok, now you have aroused my curiosity. By what definition do you consider a BBE Sonic Maximizer to be a multiband compressor? |
| Author: | Jian [ Tue Aug 18, 2009 10:41 pm ] |
Yamaha mixer (MG and the power ver) have one-knob comp built-in into the mic channels. It is easy to use and good enough for karaoke. |
| Author: | 6 String [ Wed Aug 19, 2009 12:39 am ] |
I use a Drawmer MX30 for live, I've had it for about 12 yeears. Its quite battered now, but its built like a tank and still works like new. It's a godsend, especially for those damn screetchers! The limiter is the more useful function for these guys, they can yell all they like, ain't gonna go any higher than 0db. Here's a decent guide to using compression. http://www.harmony-central.com/Effects/ ... mpression/ |
| Author: | Lonman [ Wed Aug 19, 2009 1:24 am ] |
6 String @ Wed Aug 19, 2009 1:39 am wrote: The limiter is the more useful function for these guys, they can yell all they like, ain't gonna go any higher than 0db./
Isn't that the truth! I still use & love my Symetrix 501's! |
| Author: | karaokeking211 [ Wed Aug 19, 2009 5:56 am ] |
Jian @ Wed Aug 19, 2009 12:41 am wrote: Yamaha mixer (MG and the power ver) have one-knob comp built-in into the mic channels. It is easy to use and good enough for karaoke.
I was considering the MG mixer with built in compression but heard that it wasn't worth the $$$ if I just wanted it for the built in compressors. I got a screaming deal on a Mackie Onyx 1220 and an outboard Lexicon efx processor which is a much better set up. It doesn't have compression but I figured an outboard would be better anyway. Thanks all for the feedback and I will look into your suggestions. |
| Author: | karyoker [ Wed Aug 19, 2009 6:31 am ] |
There is a difference between limiting and compressing. A peak limiter decreases the occasional peaks that would cause audio clipping or would necessitate turning the level down when recording. The rest is not compressed or affected. Compression decreases everything. Limiters are used on the overall mix but compression is not normally used but is used to balance or mix all channels or tracks. The overall mix or bus is routed to the EQ. That is where sound procs such as the Bbe are inserted to separate and add harmonics to enrich or restore the sound to the original quality or richness. Actually they expand (where necessary) rather than compress anything. It is not complicated but the biggest mistake is running too high of a level at critical stages or excessive adjustments on the compressors or procs. In fact I dont like unity gain until the mains fader but that is personal preference. |
| Author: | TopherM [ Wed Aug 19, 2009 10:21 am ] |
I think that the Behringer Ultramizer uses some compression algorythms, though it is not technically a compressor, per se. The Sonic Maximizers, however, are just a phase alligners and aural exciters if I'm not mistaken, not compressors. They actually increase bass and treble presence, whereas a compressor will kinda smoosh this presence within the compression settings to allow more power and headroom to the selected frequencies. |
| Author: | karyoker [ Wed Aug 19, 2009 10:42 am ] |
Well sort of. A compressor is not frequency selective. It limits all freqs to a threshold level without clipping or distortion. Then when mixed with another track the level can be adjusted and the "quiets" can be heard in the overall mix. This is the main reason for compression. Peak limiting protects equiptment from spikes. Compression is used for mixing and mastering. If it is adjusted into the compression range then it is distorting.. |
| Author: | jeffsw6 [ Wed Aug 19, 2009 11:14 am ] |
A Sonic Maximizer / Behringer Ultramizer is a multi-band compressor that does good things for some program material, and bad things for others. They aren't adjustable like a professional unit, and even if they were, you'd want to use a variety of settings for different program material. For this reason, IMO, they are useless for karaoke. If you were mixing a band and had a set list you could dial in presets for, you could get some benefit from it; but that's not us. And if mixing a band, you have a lot more tools available for each track, and don't need a tool like that on the whole mix anyway. Move the faders, that's what they're for. "Aural Exciter" is a marketing term. Apparently it means to "excite" the "aura" of the music. Whatever that means. Generate new harmonic content? I don't know. I don't like these things with most program material. I hit the Ultramizer button on my DDM4000 once in a while on particular songs. I wish it was available as a channel insert so I could PFL it before the song starts. |
