KARAOKE SCENE MAGAZINE ONLINE! - Venue video connection? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 3:24 am
 Post subject: Venue video connection?
PostPosted: Sun Aug 16, 2009 5:52 pm
I am setting up my laptop with mp3+g. Being new to the KJ world, I was wondering which type of vidio out I should have ready. RCA, S-video or what? Any help you can provide would be helpful.
Thanks in advance.
PostPosted: Sun Aug 16, 2009 6:05 pm
Are you using a cdg single disc player as well? If so I run both video signals into an AV switch which allows you to switch from your laptop to the single disc player. If the laptop has an s-video output I would use that. Radio shack makes a s-video to rca video cord if the TV you use only has an rca video input.
Most new laptops do not have a s-video output. If this is the case there is a piece of hardware called PCtoTV by K-world which uses your VGA output and converts it to rca, s-video or RGB. I've used this and it works well.
"Don't worry. It will feel better when it quits hurtin."
PostPosted: Sun Aug 16, 2009 6:38 pm
Been Liked: 53 times
Majority of the places you will run into will have either cable or dish service running over coaxial cable. Having a laptop with composite or s-video out and a rf modulator to convert to coax will probably cover most places.
PostPosted: Mon Aug 17, 2009 11:56 am
My mixer mixes video as well as audio, and it has RCA output. I am going from the S-Video on the pc to the $25 S-Video to RCA thing from radio shack. Any tv made in recent memory is going to have a standard A/V RCA input. This wouldn't work in all situations, but has worked for all I have done.
Felix the KJ
8)
Users browsing this forum: No registered users and 2167 guests
