KARAOKE SCENE MAGAZINE ONLINE! - Balanced or Unbalanced + Mono or Stereo Jacks??? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 4:29 am
PostPosted: Sat Aug 08, 2009 8:04 am
OMG, I'm just so confused. Please help me out.
Here is my set up -> FX unit into Mixer
Mixer - has ONE Aux Send (needs 1/4" impedance balanced jack-type output)
Mixer - has TWO Returns (needs 1/4" unbalanced phone jack-type inputs)
FX Unit - has TWO 1/4" balanced jack analog inputs
FX Unit - has TWO 1/4" balanced jack analog outputs
I think this is what I need to do:
1) "Balanced" line with "Mono" jacks to connect Mixer (ONE Aux Send) to FX (LEFT analog input) - Is this correct???
2) What do I use to connect the two FX "Balanced" Outputs to the two Mixer "Unbalanced" Returns??? Balanced or Unbalanced lines??? With Mono or Stereo Jacks???
Thanks in advance!!!
PostPosted: Sat Aug 08, 2009 9:54 am
Giving us the make and model of your mixer might help us give a more useful reply
Dave's not here.
PostPosted: Sat Aug 08, 2009 11:03 am
There is no real mystery here and the brand of equipment really has no bearing for this simple reason. TRS jacks are electronically balanced, so if you plug in a mono plug, they simply turn into an unbalanced output. For short runs you could use a simple T/S cable for both input and output. If it makes you feel better you could use a T/R/S from your mixer to your FX device and a T'S cable from your FX device back to your mixer.
PostPosted: Sat Aug 08, 2009 12:42 pm
Thanks LondonLive!
I ended up using a TRS cable to connect the Mixer's 1 Aux Send to the FX's Left Input and the 2 TS cables to connect the FX's 2 Outputs to the Mixer's 2 Returns.
Moonrider,
My Mixer is the Yamaha MG102c
http://www.zzounds.com/item--YAMMG102C
My FX unit is the TC Electronic M300
http://www.tcelectronic.com/m300.asp
Users browsing this forum: No registered users and 2156 guests
