Hooking up vocal effects to mixers without aux jacks
https://ksmo.us/forums/viewtopic.php?f=1&t=17334
Author:  stogie [ Wed Aug 05, 2009 7:37 am ]
Post subject:  Hooking up vocal effects to mixers without aux jacks
I have a couple of mixers that don't have any aux send or return jacks like my trusty EMX512 and an old American Audio Qspand DJ mixer I just got.
Is there a way to plug ANY external vocal effects processors onto these type of mixers?
The only way I've found so far is to plug my Alesis Multimix 8 mixer into a channel on these other mixers, but that defeats the purpose.
Is there a good vocal effects that can just plug into a mic channel?
Author:  Lonman [ Wed Aug 05, 2009 9:39 am ]
Post subject:  Re: Hooking up vocal effects to mixers without aux jacks
Don't know about the American Audio amp, but the Yamaha has an Effect out jack. Connect that to the external efx & run the output of the effects into an open channel making sure NOT to turn the effects up on that returned channel otherwise you will get a nasty feedback!
Author:  stogie [ Wed Aug 05, 2009 10:01 am ]
Ok, what about a regular DJ style mixer that doesn't have any aux or effects jacks?
Is there any way to go into a regular mic channel? Is there an effects unit that works that way? I only want the effects on the vocal mic, no effects on the music.
Author:  karyoker [ Wed Aug 05, 2009 11:11 am ]
Another option would be getting a tube mic preamp and the EFX unit between it and the mixer. You could use this on any of your mixers.
Author:  letitrip [ Wed Aug 05, 2009 12:28 pm ]
Just be sure if you do this you reconfigure your Effects Unit to mix in the dry signal with the effects signal on the output. Most reverb units aren't set this way by default and the result would be you'd only get the reverb, not the actual vocal itself.
Author:  Lonman [ Wed Aug 05, 2009 12:39 pm ]
You could get something designed to go inline between the mic & mixer but would only effect 1 mic only, the one plugged into it. {as mentioned above}
http://pro-audio.musiciansfriend.com/pr ... sku=150177
This is just an example, there are several others.
Author:  jeffsw6 [ Wed Aug 05, 2009 1:00 pm ]
I would just buy a new mixer. You can get a Behringer that will probably last a few years for a few hundred bucks, or something nice for a bit more. If you aren't making enough off your karaoke show to spend some money on equipment, change what you are doing.
Author:  stogie [ Wed Aug 05, 2009 1:11 pm ]
Ok, well, I guess I'll just dump those mixers on craig's list. I love my Alesis Multimix 8 and I will either get another one for a bakup or eventually get the Soundcraft EFX8 for my main mixer and keep the Alesis for a backup. The vocal effects on the Alesis are very good and I'm satisfied with them. I just figured there might be a simple and inexpensive way to just plug in decent vocal effects.
Author:  Lonman [ Wed Aug 05, 2009 1:19 pm ]
Again the Yamaha can add an external effect processor that will work with all channels. The dj mixer is the one you should drop.
Author:  stogie [ Wed Aug 05, 2009 6:32 pm ]
Thank you Lonman, appreciate the info. you always have good reliable advice.
