KARAOKE SCENE MAGAZINE ONLINE! - Software for creating a Song Book Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 4:58 am
PostPosted: Fri Jul 17, 2009 6:18 am
Been Liked: 112 times
What software (inexpensive preferred) has everyone found that does a good job for listing all the songs people will look through to pick the songs they would like to sing. thanx
PostPosted: Fri Jul 17, 2009 7:35 am
I use Fast Tracks for my books. They have two versions, one costing less than the other due to different features. The higher costing version has the ability to do either disc based lists and digital books while the cheaper version does not have those features but is stuck with disc based books. both will tie into Compuhost's database.
PostPosted: Fri Jul 17, 2009 10:11 am
ms access... do it yourself!
PostPosted: Fri Jul 17, 2009 11:01 am
Music Book Deluxe - simple to use, multiple formatting options.
PostPosted: Fri Jul 17, 2009 11:26 am
I also use Access. Great for customizing & database storgage plus entering the music in yourself, you get to know your library much better & can curb spelling errors & disc misprints the canned database/bookmakers so often have.
PostPosted: Fri Jul 17, 2009 11:40 am
Sorry to piggy-back here but, speaking of Access (which I have no experience with yet), Will it import Excel files? (which is what my current books are formatted in). As a long-term project, I’d like to create some custom books by category; such as genre & year.
JR & Michele LaPorte
Peoria, AZ
PostPosted: Fri Jul 17, 2009 6:39 pm
yes supposedly quite easily.
I'll be honest, I didn't import per say, as much as started the fields myself, and then copy and paste directly into the input area that has the separate fields... the bottom being the * field. It confirms you're posting 50 lines or so... very easy to put them all in. I tried a couple times to import, and I didn't like the results, but then again, I wasn't that big of an Access user!
PostPosted: Tue Jul 21, 2009 5:28 pm
Been Liked: 64 times
Music Book Deluxe or KJ Pro
PostPosted: Tue Jul 21, 2009 10:10 pm
KJ Pro does, with the click of a button. I also think it's the best book software out there. Yes, it will also, with a click, create any kind of custom book out there. It also has what I believe to be the best music search and import database around. Though of course you can enter tracks manually, you can also enter all info by clicking the disc number.
Plenty of fonts and styles, and will print books by title, artist, disc number, or catalogue for inventory- all with a click.
I love it, but it's no freebie. The money is well spent though. Ease of use and the resulting books make it truly worthwhile.
..... and no, I'm not associated with KJ Pro in any way- just a truly satisfied customer.
PostPosted: Wed Jul 22, 2009 11:12 am
I use FastTrack for song books myself. I really like it for a couple of reasons. While the database is not perfect, it does save me a lot of time entering karaoke disc data. Just a couple of clicks and it's done. One other feature I like is that when you choose a disc, it tells you which tracks duplicates. So, if I find a discs I like, I can type in the manu and choose the right disc, I can tell if too many of the songs are dupes, then I may choose another disc.
One of major short coming for FastTrack is the UI. The UI looks and functions like it's from the DOS era, not modern window interface. For example, if you want to make changes to multiple songs, it won't let you do it.
If you can get used to the interface, I think it's a solid product.
Seize the day and SING!!!
PostPosted: Wed Jul 22, 2009 6:51 pm
Hi Sanj,
If you have your songs ripped to hard drive there is no easier way to create a song book than Latshaw song list generator.
Mrmarog
PostPosted: Wed Jul 22, 2009 7:06 pm
mrmarog @ Wed Jul 22, 2009 8:51 pm wrote:
Hi Sanj,
Mrmarog
Agreed :!:
PostPosted: Wed Jul 22, 2009 7:23 pm
I use KJ Pro, it's very simple to use easy to update new discs that aren't loaded into KJ Pro yet. I usually update it every 6 months or so and manually add new discs.
Users browsing this forum: No registered users and 2160 guests
