KARAOKE SCENE MAGAZINE ONLINE! - Software - make a list of all mids and kars Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 8:38 am
PostPosted: Mon Jul 06, 2009 2:05 am
Hello,
I have MANY karaoke files. I would like to make an ordered list of all the songs, at least ordered by author.
Then I would like to print this list, so that people can choose by author the song they want.
Is there a fast way to achieve this?
PostPosted: Mon Jul 06, 2009 4:46 am
Other than typing in all the tracks into an microsoft excel sheet (or similar) then printing I have no idea. Either way, it is likely to be a long laborious job.
PostPosted: Mon Jul 06, 2009 5:52 am
utnalove @ Mon Jul 06, 2009 5:05 am wrote:
Hello,
I just write a script using the "find" command. But I am a programmer.
You can get Latshaw's Song List Generator and it will do things like that. Though I am not sure about kar and mid files. No one here really deals with those much.
PostPosted: Mon Jul 06, 2009 6:33 am
And what do you use instead of .mid and .kar?
Do you share the script or you keep it private?
PostPosted: Mon Jul 06, 2009 6:37 am
I would share it, but it uses Perl and find and not 1 of 100 people has the ability to run it. I could obviously modify it to handle .kar and .mid -- it looks for .zip right now.
PostPosted: Mon Jul 06, 2009 6:43 am
My specialization is Networking, but I think I can make it run.
What does this script do? Makes the list from the filename or from the informations about author and title inside the files?
PostPosted: Mon Jul 06, 2009 6:57 am
You can if you install Cygwin or maybe perl. Not otherwise.
First of all, it relies on the files being named consistently. The standard in mp3+g files, at least the most common one, is
DD1234-01 - Artist, The - Title, The.zip
It's as simple as:
cd /karaoke
find . -name '*.zip' | perl -pe 's:.*/::; s/\.zip$//; s/ - /\t/;'
An all-perl version would be:
Code:
#!/usr/bin/perl
    use File::Find;
    my $wanted = sub {
        return unless -f $_;
        s/\.(zip|kar|mid)$//i or return;
        s/ - /\t/g;
        print "$_\n";
    my $dir = shift || '.';
    File::Find::find($wanted, $dir);
You can install Strawberry Perl pretty easily (it's free, search Google).
PostPosted: Mon Jul 06, 2009 7:01 am
If all your files are in one folder and the artist (author) is the first name n the file you could use a simple directory print program. There are lots of free ones on the web.
If that didn't fit the your needs I agree with Latshaw's songbook generator but then again you have to have them named properly.
PostPosted: Mon Jul 13, 2009 5:18 am
cd /karaoke
Hello,
I have just installed strawberry perl...
This is the command and error that I am getting:
Code:
C:\Documents and Settings\me\My Documents\downloads\test>find . -name '*.zip' | C:\strawberry\perl\bin\perl.exe -pe 's:.*/::; s/\.zip$//; s/ - /\t/;'
Can't find string terminator "'" anywhere before EOF at -e line 1.
File not found - '*.zip'
PostPosted: Mon Jul 13, 2009 5:32 am
cd /karaoke
Hello,
Code:
You don't have the "find" command unless you have Cygwin or the equivalent. You are going to have to use my self-contained script.
PostPosted: Mon Jul 13, 2009 8:38 am
Been Liked: 15 times
If you still haven't got this sorted out I would be happy to help. You can get a list of files by using the command line interface in windows.
Start->Run type ""command or "cmd"
if your files are in many different directories type
cd\ <enter>
dir *.mid /s /b>mid.txt <enter>
this will give you a listing of all midi files on your computer in a file called mid.txt
if you have them all in one directory, navigate to that directory and then type:
dir *.mid /b>mid.txt
do the same thing with the kar files but instead of *.mid make it *.kar and of course the output file should be named kar.txt.
Attach these two files to an e-mail and shoot it my way along of an example of what you would like the result to look like. Use "Karaoke" as the subject so I don't delete it as junk. My e-mail address is outintheweeds-AT-hotmail.com and I'll send them back in your format. Or I'll give it a shot anyway.
Okay, who took my pants?
Users browsing this forum: No registered users and 2661 guests
