KARAOKE SCENE MAGAZINE ONLINE! - Help with making recordings. Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 6:02 am
PostPosted: Wed Jun 24, 2009 8:36 am
Hi, I have had a look about for somethnig along these lines but not seen anything as yet. If there is alredy an aswer to this then please let me know and I will delete this question.
Basically, I am not new to singing with my Karaoke machine but I recently decided that it would be a good idea to connect the machine to my PC and play the tracks in the key that I use to sing them in. That way I could put them all on one or more discs and play them without having to worry about checking the various key change levels.
Then It dawned on me that I didn't have the foggiest idea as to where to start. For one, I don't know what a decent program to use would be for recording the tracks on the PC or how to then put them all together to burn onto a disc.
Finally, I want to make backup copies of my original karaoke discs so that I can save the originals. is there a specific program to use for this.
Any help in these matters would be greatly appreciated.
Cheers
Jim
PostPosted: Wed Jun 24, 2009 12:15 pm
Go to MTU.com they have the programs that you can rip, change the key & reburn to disc. Microstudio & Keyrite will do exactly what you want.
To use the discs in the computer, you MIGHT need to get a new dvd drive. But download the demos first & check it out.
PostPosted: Wed Jun 24, 2009 12:55 pm
Thanks for the information, I will go have a look.
Cheers
PostPosted: Fri Jul 03, 2009 6:21 am
Thanks for that, I downloaded the Microstudio suite option. I now have Microstudio + Vogone, Keyrite and KHPro.
Next question, I have an RSQ NEO machine, any tips on the best way to connect this to the PC as it has lots of outputs but my pc doesn't have many input options except USB. Any ideas or advice on a card I can buy to make it easier.
One last point. The NEO has 7 key change levels in either direction. Most other machines I have seen have 5. Is 5 the standard??
Cheers
Users browsing this forum: No registered users and 2007 guests
