KARAOKE SCENE MAGAZINE ONLINE! - Lexicon MX300 & MX400 fx query Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 6:20 am
PostPosted: Mon Jun 22, 2009 5:18 am
Hi I have a question regarding the master wet/dry setting on these units.
I've seen in the manuals how the wet/dry ratio for each of the 2 effects engines can be set individually but can't see a master wet/dry parameter anywhere.
The digitized dry output will be delayed by 3.7mS @ 48kHz relative to the input causing weird out of phase effects when mixed back in with the original signal in the mixer.
My TC Electronic unit has a global mix setting which is set to 100% wet and the levels of the 2 effects engines can be set individually and stored with that patch/combination.
Thanks for any enlightenment :)
Gadget's Karaoke : Boldly singing what no one has dared sing before.
PostPosted: Mon Jun 22, 2009 7:15 am
On the 400 at least, I am not aware of a global setting. I agree with you that this would be a nice option. If there is one I haven't found, I hope someone posts it. I have never had reason to complain about the delay digital FX processors add to the dry portion of the signal anyway. I like a little bit of delay on vox.
Jeff Wheeler, moonlight DJ/KJ
Users browsing this forum: No registered users and 1799 guests
