KARAOKE SCENE MAGAZINE ONLINE! - Amplifier mode: Stereo or bridged? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 6:20 am
PostPosted: Sat Jun 20, 2009 9:22 pm
I am running an amplier that in Stereo mode puts out 230 watts at 8Ohms
and in bridged mode puts out 800 watts at 8 ohms.
My speakers run 250 RMS and 500 peak.
My question is which mode would I be better in?
I currently run it in stereo mode.
I guess I am asking am I missing anything running it in Stereo mode?
I hope I have provided enough information for a helpfull answer.
Another question: How many watts would go to each speaker if I plugged one wire on top of the other? Would that mean I actually will get 400 watts per speaker distibuted that way?
PostPosted: Sun Jun 21, 2009 6:13 am
800 watts seems a bit high for bridged mode. Is the 230 watts rms or peak? If it is rms I would use the stereo mode.
Not sure what you mean about rewiring speakers.
PostPosted: Sun Jun 21, 2009 6:40 am
If you can't bridge at 4 ohms, and move to mono, you are best off staying in stereo.
PostPosted: Sun Jun 21, 2009 6:46 am
Been Liked: 34 times
I'm sure Lonman will be the best to answer this, but here's my thoughts:
If you connect your speakers in parallel they will double the wattage and assuming they are 8 ohms the load will drop to 4 ohms.
Your 800 watts amplifier in bridge mode is under 8 ohms. now I'm not sure it will handle the 4 ohms load with having both speakers connected in parallel :roll: I'd say even your stereo setup is limit, your 230 w is till not enough to drive these speakers, you'll need the equivalent of your "peak" power of your speakers, in this case, 400-500w amp would be what you need for these speakers :wink:
PostPosted: Sun Jun 21, 2009 8:39 am
I didn't say rewire. I meant to say piggyback my connectors (banana plugs) over the top of each other. I did a search for bridging speakers and Lonman made a comment on this.
I don't know about whether it's peak.
eia standards
4ohms stereo- 400X400
8ohms stereo- 230X230
8ohms mono/bridged 800
are the specs
PostPosted: Sun Jun 21, 2009 10:06 am
What amp is it?
Micky is correct, piggybacking the speakers will drop the load to 8 ohms & whatever the PROGRAM power of the speaker at 8 ohms will double - ie if the speaker is looking to have 500 watts program at 8 ohms, they would need 1000 at 4 ohms.
Looking at the specs you provided, doesn't look as if the amp can handle a 4 ohm load bridged.
Also what speakers are you using. You may be better off running both speakers off of one channel only. Stereo in a club setting isn't anything special especially if you have the speakers placed in a position that the entire bar can't hear. Some songs are recorded the way they were originally & one side of the bar will hear things the other side won't. Even when I run bands, I rarely run stereo.
PostPosted: Sun Jun 21, 2009 10:08 am
It is a Soundtech PS800 power amp.
The sound is good in stereo but was wanting a litle more power for larger venues.
PostPosted: Sun Jun 21, 2009 10:14 am
Yeah that amp definitely can't handle a 4 ohm load in bridge mode, so that is out of the question. Again, it will handle a 4 ohm load per channel, so you can piggyback your speaker on 1 channel & just run that way for more power.
Had to do a refresher on the EIA test. With that setup they can not handle the peaks. I would think the bridged mode could though.
PostPosted: Sun Jun 21, 2009 10:17 am
It might be very beneficial to just pick up another amp for larger venues. Again what speakers are you using?
PostPosted: Sun Jun 21, 2009 10:20 am
Pyle pro 10" speakers. they actually sound good for off brand. Don't have the money for new equipment so I guess I'll do with what I got in stereo.
Also I'm limited to 1u sapce in my amp. If I got a bigger 2u amp I would have to take out either my wireless mike receivers or my powerconditioner and that's not gonna happen.
PostPosted: Sun Jun 21, 2009 11:19 am
Then instead of another amp, a good 15 or 18" powered sub would be very complimentary to those speakers & make a world of difference - even in smaller venues.
PostPosted: Sun Jun 21, 2009 11:22 am
Thank you lonman for your answers. Getting a sub isn't gonna happen as I have my vehicle full with the equipment I have when I load it all in.
Users browsing this forum: No registered users and 1799 guests
