KARAOKE SCENE MAGAZINE ONLINE! - portable USB powered hard drives Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 6:25 am
PostPosted: Thu Jun 04, 2009 4:48 am
Anyone used or had experiance of these 2.5 hard drives if they are any good to use on the road ,I use 2 Western Digital My Book Essential Edition which are quite bulky and has the power adapter to plug in ,these are very small and only need the usb to plug in.
seen some good reviews on some of them but not for the kind of work we tend to use them for.
PostPosted: Thu Jun 04, 2009 5:03 am
I like to use the internal drive on my laptop for reliability and ease of setup, but I carry one of these as a backup for a second laptop that I have (with small disk). I couldn't pass it up -- $70.00 for 320G. No big case to carry (fits easily in my laptop case).
You obviously have to be careful how you pack them, a bit. But other than that I can't see why they would be any problem at all. They seem to be fast enough to support use live, and their MTBF is at least as good as the 3.5" externals that people are so unnaccountably fond of using.
PostPosted: Thu Jun 04, 2009 5:11 am
From what ive read so far they are a bit more rigid than the 3.5 versions as they ment to be in laptops and the likes ,i only have a 40 gb in my laptop and i do a few discos so need quite a bit of music and karaoke so cant really get by with out externals otherwise i would agree internal is always the best way to go.
PostPosted: Thu Jun 04, 2009 5:35 am
I use a Seagate Free Agent 1TB Drive for karaoke and music files. It's only an issue if you have to power them off your battery for any period of time. If you're near a wall socket you're golden, found that out when I was doing some file management on an airplane because it seemed like a good way to spend time. Turns out I only got 1.5 hours of battery life instead of the normal 3. :(
I'd recommend their use as normal duty items no different than the internal in your laptop.
PostPosted: Thu Jun 04, 2009 5:44 am
Thanks for that mckyj57 and Gryf being that they not that badly priced compared to the normal powered external hard drives ,the +'s out way the negs upto now and as for battery i normally get about 3 hours too but would never run a gig on battery anyway but nice that if there was a problem that you could get away with it for a short while.
PostPosted: Thu Jun 04, 2009 6:27 am
I have one of the little Western Digital passports. 320 gig and works fantastic.
They come in all sizes and colors...and cheap these days!
PostPosted: Thu Jun 04, 2009 7:19 am
By the way Gryf you say a free agent 1TB the only ones i see that run from the USB are the free agent Go and as far as i can tell they go upto 500gb.
PostPosted: Thu Jun 04, 2009 11:33 am
I have a Toshiba 320g 2.5" external that works great. No problems whatsoever with 5 times/week karaoke use.
PostPosted: Thu Jun 04, 2009 1:19 pm
Those USB drive are pretty cheap around here..
Just bought a 1 T external, (AC power) for $94.00
You may wish to pick up an adapter to connect any drive to the USB port.. $20.00
Yes, the USB port will run all size drives..
PostPosted: Thu Jun 04, 2009 1:23 pm
What you mean a adapter to conect any drive to the usb?
PostPosted: Thu Jun 04, 2009 1:39 pm
You can get an external case for a regular internal drive that will connect via USB. I have several of these that I use for different drives that I may need. Alot cheaper than buying a regular external drive of the same size & it can be upgraded easily.
http://www.newegg.com/Product/Product.a ... 6817145133
PostPosted: Thu Jun 04, 2009 1:43 pm
Ok yeah i have a couple like that on my desktop at home ,i thought he ment to turn any into powered by the usb .
i like the idea of smaller externals with less cables.
PostPosted: Fri Jun 05, 2009 7:34 pm
http://www.tigerdirect.com/applications ... kwCjCECjCE
PostPosted: Sat Jun 06, 2009 8:09 am
I have been using Seagate 500g free agent usb powered drives and they have worked flawlessly. I have bought them on sale and they are reasonable @ $99
PostPosted: Sat Jun 06, 2009 8:49 am
Apologies, got my sizing mixed up. The Go only come in the 500 GB max capacity. The 1 TB needs a power outlet. Sorry for the confusion.
PostPosted: Sat Jun 06, 2009 10:36 am
jdmeister @ Sat Jun 06, 2009 4:34 am wrote:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=3249952&SRCCODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
Thanks jdmeister but i was on about making any of the external hubs self powered.
but good tool too.
PostPosted: Sat Jun 06, 2009 10:38 am
No Problem Gryf we all make mistakes ,the mistake i made was getting in this business lol ,we never finished buying stuff lol.
PostPosted: Fri Jun 12, 2009 1:17 am
sonnerie portable gratuite
PostPosted: Fri Jun 12, 2009 8:01 am
That was the reason i asked normal reviews for home dont apply.
PostPosted: Tue Jun 16, 2009 9:55 am
My sister runs The Karaoke Chicks NJ with a usb powered 320 gig hard drive with no problems, BUT she doesn't use a usb light, & usb sound card like I do. Then add in the dongle from compuhost and you are out of USB ports on most computers.
I have tried the powered usb drives, and my only complaint is they need to be plugged into the main USB port that is direct to the motherboard, The other usb ports on my computer (the ones on the front) will not power it. Alot of the passport drives cannot be plugged into a HUB, which most laptops have internally, and regular PC's with ports on the front.
Just my personal experience I thought I would share with ya'll.
[font=Cursive]Don't Just Stand There.....SING something![/font]
Users browsing this forum: No registered users and 1880 guests
