KARAOKE SCENE MAGAZINE ONLINE! - usb question ??? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 6:02 am
 Post subject: usb question ???
PostPosted: Tue Jun 02, 2009 6:23 am
How many things can you hook up to your computer though usb ports???
My Sony Vaio has 4 ports but I use some splitters to accommodate the 7-8 items I hook up. So far, I don't seem to have any problems but I was wondering if I may have some conflicts in the future.
Mojo
 Post subject: Re: usb question ???
PostPosted: Tue Jun 02, 2009 7:50 am
Good question although I don't know the answer. I suppose that as long as you are not accessing all the ports at one time things should be ok. What are you hooking up that you need that many ports?
Lone Wolf
PostPosted: Tue Jun 02, 2009 9:36 am
Here's where they go Lone Wolf
1 compuhost dongle thingy
2 lines to my Numark C3DJ mixer
2 lines to external harddrives
1 to the Gigaware (pc to TV converter)
1 to a mouse
1 flashdrive when needed
I know, I know, I need to get rid of one of the harddrives. And I'm sure people are gonna tell me to get a different mixer(I run the DJ mixer into a alesis MultiMix 8)but this system works well for me. I just don't want to have some sorta usb overload.
Mojo
PostPosted: Tue Jun 02, 2009 9:44 am
Dont worry. Ever...
256 is the number you are looking for.
PostPosted: Tue Jun 02, 2009 10:12 am
I have 7 items hooked up at all times with 6 ports available. 3 drives, 1 Audio interface, 1 wireless internet modem, wireless mouse, external card reader with 4 extra USB ports. I sometimes get a USB exceeded error when using all at once & it won't recognize something new or will wait until I take out something.
PostPosted: Tue Jun 02, 2009 11:30 am
The real limit to USB or number of peripharals is the wattage of the power supply. Sadly the trend right now is manus scimping on power supplies with in adequate wattage.
The cure is using hubs with separate power supplies.
PostPosted: Wed Jun 03, 2009 4:01 am
The limit is actually 127.. and the USB bus is a shared connection which can slow some transactions down, as the CPU/Data bus runs requests in one queue.
How many USB devices can I connect to a PC?
USB allows you to connect a maximum of 127 devices at a time, of course this is via serveral hubs and interlinked connections.
USB devices are linked in series through hubs. There always exists one hub known as the root hub, which is built into the host controller. So-called "sharing hubs", which allow multiple computers to access the same peripheral device(s), also exist and work by switching access between PCs, either automatically or manually. They are popular in small-office environments. In network terms, they converge rather than diverge branches.
A physical USB device may consist of several logical sub-devices that are referred to as device functions. A single device may provide several functions, for example, a webcam (video device function) with a built-in microphone (audio device function).
USB device communication is based on pipes (logical channels). Pipes are connections from the host controller to a logical entity on the device named an endpoint. The term endpoint is occasionally used to incorrectly refer to the pipe. A USB device can have up to 32 active pipes, 16 into the host controller and 16 out of the controller.
Each endpoint can transfer data in one direction only, either into or out of the device, so each pipe is uni-directional. Endpoints are grouped into interfaces and each interface is associated with a single device function. An exception to this is endpoint zero, which is used for device configuration and which is not associated with any interface.
When a USB device is first connected to a USB host, the USB device enumeration process is started. The enumeration starts by sending a reset signal to the USB device. The speed of the USB device is determined during the reset signaling. After reset, the USB device's information is read by the host, then the device is assigned a unique 7-bit address. If the device is supported by the host, the device drivers needed for communicating with the device are loaded and the device is set to a configured state. If the USB host is restarted, the enumeration process is repeated for all connected devices.
The host controller directs traffic flow to devices, so no USB device can transfer any data on the bus without an explicit request from the host controller. In USB 2.0, host controller polls the bus for traffic, usually in a round-robin fashion. In SuperSpeed USB, connected devices can request service from host.
Yes, some USB devices are bus powered, and some have a power supply.
Too many un-powered devices can cause the bus to stumble. (Low voltage)
PostPosted: Wed Jun 03, 2009 3:31 pm
Actually, the realistic number is less than 127. If you think about it, unless you have a computer with 16 USB ports, you are limited on how many hubs you can attach to each port. Each of the hubs will take one of 8 ports available, so the real number is 7 you can use. So, if you do the math, 7*16 equals 112, still a big number but can't really reach the theoretical maximum number.
Seize the day and SING!!!
PostPosted: Wed Jun 03, 2009 3:52 pm
All true, even though the spec says it will work, it never does.. :mrgreen:
PostPosted: Wed Jul 01, 2009 2:27 pm
Lonman, what brand or type of audio interface do you use? Thanks. Nitecat
PostPosted: Wed Jul 01, 2009 3:59 pm
Lexicon Alpha.
PostPosted: Wed Jul 01, 2009 4:28 pm
I too have not enough ports. I have my external hard drive, my interface, my dongle, my cooling fan, and a gooseneck light. I found a $4 hub at Walgreens that changes 1 to 4. Problem is if I try to hook up my dongle or hard drive to it, the laptop won't recognize them. When I plug them in, you can hear it on the speakers but still not recognized. Some nights I end up unplugging my cooling fan.
PostPosted: Wed Jul 01, 2009 4:43 pm
I plug my mouse and sound card into the back of my laptop. I plug my hard drive and dongle into a PCMIA usb card without any trouble. The card is a Buslink USB 2.0 cardbus for notebook.
http://cgi.ebay.com/Buslink-USB-2-0-Car ... 7C294%3A50
I paid more for it because I bought it at Officemax.
PostPosted: Thu Jul 02, 2009 7:51 am
This solution adds another "Root Hub" to the computer, and should work quite well..
The $4.00 WalMart hub may not be "Powered" with an AC adapter.. This may be the issue.. Not enough power..
PostPosted: Thu Jul 02, 2009 12:46 pm
I would pput the hard drive directly to the USB 2.0 port and move the keyboard to the PCMCIA based USB port. The speed of the USB 2.0 in it's native mode is much higher than PCMCIA speed so you are better off putting the highest bandwidth item, the hard drive, directly to the computer for better performance.
PostPosted: Fri Jul 03, 2009 6:26 am
It;s never a good idea to put an internet dongle in a hub. You should always have that it it's own independent slot. That way you won't get periodic signal loss.
Users browsing this forum: No registered users and 2007 guests
