[ 2 posts ] |
icantgetznosleep
Posted: Tue Mar 23, 2004 12:04 am |
Joined: Wed Jun 18, 2003 10:00 pm Posts: 23 Been Liked: 0 time
hi sammy. took your advice and got the microverb 4 off ebay for $100 shipped. last time you told me i cold hook it up to my audio2k akj7150 like below:
A. Plug your microphone into your effector and plug your effector into your mixer, so you'll need a 1/4 to 1/4 patch cord
or
B. In the back of your 7150 there is a microphone effects loop connection in the back, so you'll need to get 2 patch cords 1/4 male to RCA. From the back of the amp, the RCA that says "Send" or "Out", that's going to go into the "In" side of your effector and the "Out " of the effector is going to go to the "In" of the effector loop.
..........i chose to take option 'A' because it requires less wires. now is there a difference between the two ways or no? i have initially tried to play with it but am having a tough time finding the right settings.
while using the alesis, should i set main echo, delay and repeat on my mixer to 12 o'clock?
also what program number do you recommend for a small living room? and what program number are you using right now for vocals.
thanks for the help.
KjSammy
Posted: Tue Mar 23, 2004 10:19 am |
| Major Poster |
Joined: Wed Jun 05, 2002 9:27 pm Posts: 88 Location: Los Angeles, California Been Liked: 3 times
The echo setting on your Audio 2000 7150 should be off (all the way to the left).
This is not an exact science ... so follow closely
First of all, turn down the microphone volume down on your 7150. Not off, but just enough where you can scream and not hurt anything. Turn it up later when you get comfortable.
We're going to start from the left to the right of your Alesis.
The Input level, set that about 11'o clock
The Mix, turn that off for now (all the way to the left)
The Output, Set that about 10' o clock
The Value, start with 22
Edit A and B start at 12' o clock
The Mix, (you can use the terms dry and wet, dry being to the left and wet being to the left) turn that to about 10' o clock. When using the Mix, that determines how much of the signal gets processed.
I think... (it's been a while) if you set the Value to 66, turn the mix all the way to the right and play with the edit A knob, youy can get the Darth Vader on helium action.
Good Choice,
Sammy
_________________ The opinions of Sammy do not necessarily reflect the views of the Karaoke Scene Magazine - Advice is given with a sence of humor and should be taken accordingly - If you have problems setting the clock on your VCR - You've come to the right place
[ 2 posts ] |
Users browsing this forum: No registered users and 3004 guests |
