| stage monitor https://ksmo.us/forums/viewtopic.php?f=1&t=16745 |
| Author: | ripman8 [ Mon Jun 01, 2009 10:01 am ] |
| Post subject: | stage monitor |
Ok, I want to try using one of my behringer 215As as a stage monitor. Play with it here at home, if I like it, I might use it Thursday. What do I run this thru on my Yamaha MG124CX? |
| Author: | mckyj57 [ Mon Jun 01, 2009 10:09 am ] |
| Post subject: | Re: stage monitor |
ripman8 @ Mon Jun 01, 2009 1:01 pm wrote: Ok, I want to try using one of my behringer 215As as a stage monitor. Play with it here at home, if I like it, I might use it Thursday. What do I run this thru on my Yamaha MG124CX?
Aux. Look at the diagram in the manual. You connect it to the Aux send. Adjust the mix of music and vocals with the Aux knob on each channel. Simple. |
| Author: | ripman8 [ Mon Jun 01, 2009 11:38 am ] |
I'll try that, thanks. I couldn't find my manual. I'll do the online one if I have to. |
| Author: | ripman8 [ Mon Jun 01, 2009 12:27 pm ] |
That worked. Now I know what the aux knob is for on each channel. What's a horn? |
| Author: | letitrip [ Tue Jun 02, 2009 8:15 am ] |
ripman8 @ Mon Jun 01, 2009 2:27 pm wrote: That worked. Now I know what the aux knob is for on each channel.
What's a horn? A horn is typically the term used to describe the small diaphragm driver responsible for producing higher frequency sounds. To put it in layman's terms, in a two way speaker cabinet, the horn is usually the top speaker mounted inside a plastic wave guide which usually produces all the sound from around 2Khz on up. |
| Author: | mckyj57 [ Tue Jun 02, 2009 10:05 am ] |
letitrip @ Tue Jun 02, 2009 11:15 am wrote: ripman8 @ Mon Jun 01, 2009 2:27 pm wrote: That worked. Now I know what the aux knob is for on each channel. What's a horn? A horn is typically the term used to describe the small diaphragm driver responsible for producing higher frequency sounds. To put it in layman's terms, in a two way speaker cabinet, the horn is usually the top speaker mounted inside a plastic wave guide which usually produces all the sound from around 2Khz on up. He was giving me a hard time. Ripman8 has a tendency, to, ahem, be quantitatively large in the number of questions he asks. Normally I just ignore anyone who constantly asks the next question when you answer one, but one time he I told him he was asking the obvious and he got a bit upset. I still think people ought to look some stuff up for themselves. Other people are of the "no question is a stupid question" bent. I disagree with that. No *first* question is stupid, but once you have been initiated into a community there *are* stupid questions -- the ones where it becomes obvious you aren't doing any thinking for yourself. |
| Author: | letitrip [ Tue Jun 02, 2009 10:20 am ] |
Ahh whoops, I wondered if the question might be sarcastic but didn't want to insult anyone either |
| Author: | ripman8 [ Tue Jun 02, 2009 12:32 pm ] |
Actually I was giving him an easy time. He's been helpful to me in the last 6+ months. |
