KARAOKE SCENE MAGAZINE ONLINE! - Why does my audio BREAK. Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 6:37 am
 Post subject: Why does my audio BREAK.
PostPosted: Sat May 30, 2009 3:51 pm
Hi, I have just started Karaoke after saying "yes I will do it" when I should have said "No"...
I am using Winamp with a 500Gb external USB drive (400G used).
When I search the audio glitches. Can stop for 2 sec's.
I know... Too many disco tracks.
You people dont have this problem.
Why do I.
I use Nlite. I use a usb sound card.
I use alchahol moderatly. I use a 1.8Ghz Tosh. 2G mem.
I have the same results on my 2.8 desktop.(Not using Nlite).
My sound is awesome. Big deal... It breaks.
Help... Please...
Regards, Jerry
PostPosted: Sat May 30, 2009 5:23 pm
Using winamp, sometimes I used to get glitches when I ran windows explorer searches.
What I did was create a .txt listing of my master book and leave it on in the background. Do not use your windows search for windows explorer... talk about a windows resource hog! have the filesystem up on the karaoke drive, and just go to the appropriate folder.
PostPosted: Sun May 31, 2009 5:37 am
Try increasing the size of the winamp output buffer. It's been years since I had this problem, so I do not know where it is in the menus anymore; but I bet it is still an option. Dig through the preferences screens.
Jeff Wheeler, moonlight DJ/KJ
PostPosted: Sun May 31, 2009 6:59 am
USB external drive and USB sound card? Doesn't sound like a good combo to me....
Try switching to the internal sound card and seeing if you get the same behavior.
PostPosted: Sun May 31, 2009 7:20 am
What OS? Cntrl Alt Del with winamp playing. Tell me what the CPU usage percentage is. Commit charge?? Click on the processes tab How many do you have running.?
Is it a generic box or one with all the manus crap running? You need to get rid of all the crap running in the background.
Go into display properties and set the theme to windows classic.
PostPosted: Sun May 31, 2009 7:27 am
It is under "Options" "Preferences" Plug-ins" "Output" "Nullsoft DirectSound Output"
Highlight the "Nullsoft DirectSound Output" and click "configure" and then go to the buffering tab.
What are you using for your searches? - Windows explorer or the Winamp search feature?
Start with karyokers suggestions above first.
PostPosted: Sun May 31, 2009 7:32 am
xptips
register
An old test is this.. ACC System Tools System Info.. Click on tools. Direct X Diag.
Run these tests with Winamp playing over and over At a certain point you will start overloading and have audio drops.
PostPosted: Sun May 31, 2009 7:48 pm
Trying the other sound card is a good troubleshooting suggestion. Maybe there is something wrong with the USB one.
There should be no appreciable USB contention when doing things like file-system searches. The I/O will be seek-heavy and not have a high transfer rate. Your comment does make me curious how USB resources are allocated when the bus is over-subscribed, though. I wouldn't worry about it having anything to do with the combination of USB hard drive and USB sound card.
PostPosted: Mon Jun 01, 2009 7:32 am
The other option in winamp that I've found helpful in situations like this (when I had an older laptop) was to adjust the process priority. Although WinAmp says it's not recommended, in this case I would say put it at it's highest priority. Normally on a PC you were using for multiple purposes you wouldn't want this, but in this case it's sole purpose is to run that music so jack up the process priority and see how that goes as well as the other suggestions listed here.
DJ Tony
PostPosted: Mon Jun 01, 2009 9:11 am
Also if you are installing a PCI sound card and a video card put the sound card closer to the middle of the motherboard than the video. This will give it a lower IRQ and it will have higher priority than video.
Sometimes you have the option of reassigning IRQ,s but it's been so long I forget how. It might be in the Device Manager.
PostPosted: Mon Jun 01, 2009 12:32 pm
Jerry,
I have almost the same specs as you list, but hp lappy. I use a external hd, and the usb sound interface, winamp, windows vista, 2gb mem, nothing else running but winamp. I also get the *glitches* when searching. I was going to double the memory and I try not to search too much, but it is a problem. I'm interested in a fix. I always use winamp search and do NOTHING else when using the cpu. I'm am going to explore the buffer option, if can be found and maybe adjusting the priority. If you do find a option that works, please share. I will do the same! Thanks, MrD
[highlight=midnightblue]MrD - KJ/DJ Specialist
Visit MrD on facebook - mrdsentertainment
& on myspace - larrynance[/highlight]
PostPosted: Tue Jun 02, 2009 9:48 am
Thanks for all your ideas.
I will go through them over the next couple of days.
I am running XP pro.
Trouble is it does not often do it.
Gig night it does.
PostPosted: Thu Jun 04, 2009 2:17 pm
Red face have I.
Must have upset something with the Nlite build.
I loaded a slower Dell D400 with only 512 Mb ram.
Used a straight XP pro install and removed windows components.
Ran perfectly.
I want to stop other windows services but they are so interdependent.
Does anyone know what is safe to disable...
PostPosted: Thu Jun 04, 2009 2:24 pm
Been Liked: 34 times
jerry12x @ Thu Jun 04, 2009 5:17 pm wrote:
Red face have I.
Ran perfectly.
You go to Start, Run, type msconfig, startup and removed everything except antivirus & anything with rundll :wink: If you don't need internet, I suggest removing SP3, 512mb of ram is not enough...
PostPosted: Thu Jun 04, 2009 2:33 pm
I don't think it is that simple.
I am running SP2 with internet services and explorer removed.
After searching on google I have found posts about systems hanging
because certain threads will keep demanding a service that is disabled.
Services is pretty good for showing dependencies, but not always.
PostPosted: Thu Jun 04, 2009 2:51 pm
For those you are not sure of google them. When making a major overhaul always make a restore point. I dont use the restore discs any more on laptops I put on a clean XP install and lose all the mnaus crap.
PostPosted: Thu Jun 04, 2009 4:21 pm
Good suggestion, all you need to do is go back to day one :wink:
PostPosted: Fri Jun 05, 2009 5:56 am
I do this all the time with no problem. Must be something else...
Users browsing this forum: No registered users and 1950 guests
