KARAOKE SCENE MAGAZINE ONLINE! - XLR cables for powered speakers - any specific requirements? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 7:54 am
PostPosted: Tue May 26, 2009 4:39 pm
Is there any specific requirements when selecting XLR cables to connect powered speakers to a mixer? Are they interchangeable with XLR cables for mic or not at all?
Also, when to use balanced vs. unbalanced and what should I get?
Thanks.
PostPosted: Tue May 26, 2009 5:46 pm
Go with XLR balanced. The longer the cable is the more you would need them. They cancel noise and interference and greatly maintain the quality of your signal.
PostPosted: Tue May 26, 2009 6:01 pm
XLR-XLR cables are by definition balanced. That is your regular microphone cable. If you have an XLR out from your mixer they are the best by far to use.
Some people recommend only the lifetime guarantee mic cables. I find them pricy for speaker connects which don't get much strain. I personally have bought Whirlwind 20' cables and then use multiple ones if I need longer runs.
http://www.zzounds.com/item--WHRMC20
You can get ten for $75.00 shipped, and they are good quality. Haven't had one fail yet, though I do use the lifetime guarantee cables for my two main mics.
PostPosted: Tue May 26, 2009 6:30 pm
XLR is merely the trade name for the Cannon connector. When the negative phase of the differential pair is attached to ground or not connected at all it becomes an unbalanced line. It can also be used for stereo and digital audio.
Similarly a 1/4" RTS connector by definition is only "ring-tip-sleeve" but can be use as balanced, unbalanced, stereo, telephone, effects return/send etc.
PostPosted: Tue May 26, 2009 7:02 pm
Thanks a bunch to all the gurus for all the helpful feedback... and as responsive as always.
PostPosted: Tue May 26, 2009 7:41 pm
All that is technically correct but meaningless in the pro audio world. XLR cables, i.e. mic cables, are all the same. I was wrong to say "by definition". I should have said simply that XLR-XLR mic cables will be balanced cables. You can't buy a pre-made XLR-XLR from an audio store that is not.
PostPosted: Wed May 27, 2009 8:36 pm
[/quote]All that is technically correct but meaningless in the pro audio world.[/quote]
That is completely accurate and definitive in the pro audio world. Your use of the term "pro audio world" should be "karaoke world". There's a greater audio world out there that you obviously are not aware of.
[/quote]XLR cables, i.e. mic cables, are all the same. I was wrong to say "by definition". I should have said simply that XLR-XLR mic cables will be balanced cables. You can't buy a pre-made XLR-XLR from an audio store that is not.[/quote]
You could simply state an xlr mic cable. I was merely clarifying the difference in the original post between balanced and unbalanced since a differential input can be used for both and an xlr mic can be used for both.
Users browsing this forum: No registered users and 1995 guests
