KARAOKE SCENE MAGAZINE ONLINE! - Software player? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 8:16 am
 Post subject: Software player?
PostPosted: Sun May 10, 2009 7:25 pm
Do any of you use a software player in your computer? I have a venue I am temping at that uses VGA for their projector and makes it impossible to have a player connected to it. Are there any software players that are worth a darn?
 Post subject: Re: Software player?
PostPosted: Sun May 10, 2009 7:49 pm
I am surprised there isn't a sticky thread about karaoke player software. I will post what I use.
I use RoxBox http://www.roxbox.net/.
* cost $79, demo mode is crippled but you can still see how it works
* uses winamp for playback, installs key / tempo changer
* plays MP3+G in ZIP files or not zipped
* search feature is extremely fast even with a large database
* database import: about 20 file / directory name format choices, and ID3 tags. using ID3 tags is very slow to import but does not affect playback speed.
* singer history is crude but works
* you can create 2 CDG lyric windows, one for your laptop screen and one for the TV
* possible to use built-in cross-fader to play music between karaoke singers, but I have had bad experience with this feature (bugs)
* Windows XP & Vista compatible, read the RoxBox forums to learn how to run the program in "administrator mode" on Vista or you will have problems!
* support forum seems to be fairly active, and the developer has responded to me when I emailed him within a day or two. I do not pay attention to how often new versions come out with bug fixes, etc.
Jeff Wheeler, moonlight DJ/KJ
PostPosted: Mon May 11, 2009 10:42 am
You can get a converter that will take your players RCA video out & convert to VGA.
http://www.svideo.com/video2vga1.html
As far as Software, I use MTU Hoster. Very satisfied, easy to use.
PostPosted: Mon May 11, 2009 5:48 pm
I use Compuhost after testing just about every software out there. All have their pluses but for ME the software that meets my needs is compuhost. I say test all the demos and find the one that meets your needs.
PostPosted: Tue May 12, 2009 7:17 am
It occurs to me my first post wasn't very succinct in expressing my need. I use Compuhost already to run the show. I don't think there is a better program for my use and methods. My biggest complaint is they don't play CD+G disks from the drive; I have to rip and store them. Not a big deal in general, just a hassle and open to some as piracy.
I'd like a nice utility that simply plays the CD+G off the disk drive just like it were an old fashioned karaoke player. Makes all the wiring and such much simpler if I got rid of the CD player.
So: Is there any software out there that makes your PC a simple CD+G player for running things off disk?
My apologies for being obtuse in the OP.
PostPosted: Tue May 12, 2009 7:24 am
Siglos Player/Recorder available at powerkaraoke.com. Though I have had trouble with skipping on the playing song on CompuHost if I put the disk in before the previous song has finished, it works fine if you just wait for the previous song to end before pushing in the disk.
PostPosted: Tue May 12, 2009 11:17 am
As I understand, CH has a part of the program that you can get a video capture card & run an external player for those customer discs.
MTU Hoster plays customer discs - with many drives that aren't even specified cdg compatible. I believe you can get a plug in for Winamp that will play cdg's, but have heard your drive needs to be cdg compatible.
PostPosted: Tue May 12, 2009 1:00 pm
You are correct.
PostPosted: Tue May 12, 2009 2:29 pm
For cd's I use the original player from the Cavs package I first bought to start ripping. It plays files or cd's The cd drive does have to be cdg compatible.
When it loads a cd it lists the track numbers and you click on the track you want. I used bothy th pe and sp player.
Google Cavs-usa..
PostPosted: Tue May 12, 2009 3:11 pm
Been Liked: 54 times
I use CompuHost, too. For direct disc play, I use Kara Fun. It's free and get's the job done.
PostPosted: Fri May 15, 2009 8:33 pm
pcdj kj is a great program gives you 2 regplayers and a karaoke player with external window support and you can have a mix in headphones off of a seperate channel.
PostPosted: Fri May 15, 2009 9:32 pm
Is that the one that shows you the entire file name including c:\ instead of showing brand or artist info?
PostPosted: Sat May 16, 2009 7:18 am
I have MTU Hoster loaded on my laptop. It has a feature that allows playing CDG's and Video Discs.
I have an external Plextor Burner in my case that is always connected via USB for this purpose.
FlipSide Karaoke
Scott
PostPosted: Sat May 16, 2009 6:17 pm
you can set pcdj to show whatever you want for a naming scheme .Much like when ripping cdg you pick the naming convention you want to see.
PostPosted: Sat May 16, 2009 9:20 pm
Been Liked: 8 times
gryf winamp (free) has a plug in that will play cdg discs (also free I think) so all you need for that is winamp with plug in installed
PostPosted: Sat May 16, 2009 9:22 pm
Been Liked: 8 times
duh I really need to read before typing I see lonnie and RLC have already covered that :oops:
PostPosted: Sat May 16, 2009 9:31 pm
Apparently their defaults are poor, because every time I see it all you can see for the song type is "F:\\Karaoke\Downlo....." or "F:\\My Download\...." :?
PostPosted: Sun May 17, 2009 9:28 am
Already had Kara fun installed and didn't know it played disks and it works like a charm.
Thanks for all the options folks!
PostPosted: Sun May 17, 2009 11:59 am
Been Liked: 20 times
So if you use KaraFun with Compuhost, do you just hit external from the compuhost screen, then insert the disc in your computer, and the lyrics will work with Compuhost just like you were using an External player??? Sorry, not trying to highjack the thread, but I use Compuhost with an external player (for people with their own discs), but if I don't have to set up a player, then I would just use the KaraFun.
Rosario
PostPosted: Mon May 18, 2009 5:12 am
I just minimized Compuhost. Didn't think to try the external bit. I'll experiment a bit more and report my results.
Users browsing this forum: No registered users and 2241 guests
