KARAOKE SCENE MAGAZINE ONLINE! - Double lyrics monitor Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 8:07 am
 Post subject: Double lyrics monitor
PostPosted: Mon May 25, 2009 2:22 pm
I'm about ready to buy a brand new 20" flat panel monitor for $115. I don't want to have to depend on the venue to supply a tv to display my lyrics to the audience. I chose this size as it will fit in my gator and I can either have it on the back side of my monitor stand or I could place it elsewhere.
My question is: I have a splitter vga cable. If I put both monitors on my stand, I should be able to run from my laptop to the two monitors and display on both correct? If not, I will look towards buying a tv instead.
PostPosted: Mon May 25, 2009 4:44 pm
That will work fine. The VGA to RCA converters I use actually come with a VGA splitter cable so you can connect the box for a TV output and still use a VGA monitor if you want to. I tested it successfully but I never actually used it for a show.
Jeff Wheeler, moonlight DJ/KJ
PostPosted: Tue May 26, 2009 6:47 am
Users browsing this forum: No registered users and 2457 guests
