KARAOKE SCENE MAGAZINE ONLINE! - two monitors in Sax n Dotty Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 8:53 am
PostPosted: Sat Apr 18, 2009 10:35 am
Hi there anybody? :)
I 'm from Belgium :o and I resently start to work with Sax-n-Dotty show presenter.
I want to know how I can work on two monitors.Until now I select the Expension monitor settings in windows XL but when I try to open full screen on monitor 2 the screen jumps back to monitor 1 ,only drag and size the cd+g screen works; but then there is no cdg screen on my monitor 1 is this normal ?Or is there a trick? Please reply in simple terms I'm Dutch
PostPosted: Sat Apr 18, 2009 1:24 pm
Usually you right click on the display and select display 1 or display 2. You want display 2, then double-click to take it fullscreen.
PostPosted: Sat Apr 18, 2009 2:30 pm
This feature is not dependent upon the hosting software you are using.
I have one computer that does exactly what you're describing and the manufacturer explained that in spite of what I see under the "graphics options", my equipment doesn't support an "extended desktop" monitor!
PostPosted: Sat Apr 18, 2009 11:02 pm
Thanks for answering my question ,but I think my laptop does support extended monitor only problem is to keep the full screen on monitor 2. If I don't open the full screen there is no problem except for the fact that there is no lyrics on my monitor 1
PostPosted: Sun Apr 19, 2009 3:55 am
full screen always reverts back ,same on mine i just drag and stratch sreen to full size and thats how it always stops on each start up so no need to use full screen button.
by the way u do the same with the audience screen.
PostPosted: Sun Apr 19, 2009 5:25 am
2 things:
You say you only have one lyrics screen- to get a second lyrics screen see the second post in this thread --> http://www.karaoke-forum.com/viewtopic.php?t=16381 However do not make the 2 ".ini" files read only at this point- wait to do this (if at all) until everything is just as you want.
Then once you have 2 lyrics screens do this: In Winamp select "Options" - "Preferences" then under "Plug Ins" select "General Purpose"
Double click on the plug in named MP3+G Plug-In (gen_cdg2.dll) and change the "Full Screen Monitor" box to "Display 2"
Users browsing this forum: No registered users and 3005 guests
