Passive Floor Monitors
https://ksmo.us/forums/viewtopic.php?f=1&t=16331
Author:  JDrifter [ Sun Apr 05, 2009 11:43 am ]
Post subject:  Passive Floor Monitors
I have a Carvin DCM2500 which I use to drive a Carvin TRX 118 sub. I need to add a floor monitor and thinking of using the extra channel on the DCM2500 to drive it. Is this possible without blowing up the floor monitor? Here are the specs for the DCM2500:
DCM POWER AMP SPECIFICATIONS:
DCM2500
Bridged RMS Continuous
4Ω, (20-20k Hz, <1.0%) 2500w
8Ω, (20-20k Hz, <1.0%) 1700w
Both Channels RMS Continuous
2Ω (20-20k Hz, <1.0%) 1250/1250w
4Ω (20-20k Hz, <1.0%) 850/850w
8Ω (20-20k Hz, <1.0%) 500/500w
Here are my choices for the floor monitors:
Carvin TRx12N 12" 2-Way Monitor
LIST PRICE: $795.00
DIRECT: $399.00
SALE: $349.00
System Type: 12" 2-Way Monitor
Speaker: Heavy-Duty 12" Woofer
Neodymium 1-inch exit, 1.5" inch VC, HF driver
Power: 300W Cont. / 600W Program / 1200W Peak
Recommended Amp Power: 450W - 900W
Connections: Two Neutrik™ Speakon
Pole mount cup
Dimensions: 27" high x 15.5" wide x 15.25" deep
Weight: 33 lbs
Carvin LS1202M 12" 2-Way Monitor
LIST PRICE: $499.00
DIRECT: $249.00
SALE: $199.00
System Type: 12-inch 2-Way Speaker, Bass-Reflex
1" titanium HF driver, 1.5" voice coil
Recommended Amplifier Power: 450W - 9000W
Impedance: 8 ohms
Connections: Neutrik™ Speakon & 1/4"
Dimensions.: 22.75" high x 15.5" wide x 14.75" deep
Weight: 33 lbs
Carvin LM12 Molded 12" 2-Way Main/Monitor
LIST PRICE: $395.00
DIRECT: $249.00
SALE: $219.00
Neodymium 1.5" titanium HF driver, 2.5" LF voice coil
Pole mount cup, 4 fly points
Dimensions: 24.375" high x 16" wide x 13.125" deep
Weight: 26 lbs
Yorkville NX35
System Type 2-Way
Active or Passive Passive
Program Power (Watts) 350
Biampable No
Nominal Impedance (Ohms) 8
Sensitivity (dB @1Watt/1m) 100
Max SPL (dB) 125
Frequency Response (Hz +/- 3db) 60 - 18k
Crossover Frequency (Hz) 2k
Driver Configuration 12 inch / 1 inch
HF Driver(s) 1.4-inch Aluminum with Neodymium Driver / 1-inch exit
HF Impedance (Ohms) 8
HF Dispersion (°H x °V) 80 x 50
HF Protection Dual bulb CTL™
LF Driver(s) 12 inch Neodymium Magnet, 2.5 inch voicecoil
LF Program Power(Watts) 350
LF Impedance(Ohms) 8
Inputs - 1/4" Jacks 2
Inputs - Speakon 4-pin 2
Feet Yes
Flying Hardware 1/4-20 x 5 - 2 (Top), 2 (Bottom), 1 (Pullback)
Optional Flying Hardware NXF Flyware
Bar Handles 1 (Side)
Pole Mount Adapter (1 3/8"-3.5cm) Yes
Enclosure Materials Molded Polypropylene
Grille Black Perforated Metal
Covering / Finish Black
Dimensions (DWH xbackW, inches) 12.25 x 13.5 x 26.25 x 8.5
Dimensions (DWH xbackW, cm) 31 x 34.25 x 66.5 x 21.5
Weight (lbs/kg) 28 / 12.7
Price: $411.00
Am I really better off trying to use the DCM2500 with a passive monitor or just go ahead and buy a powered monitor? I am thinking of buying instead the Yorkville NX25P ($450.00) or other powered floor monitors, but they are more expensive. Is it worth spending the extra dollars for the floor monitors or would the cheaper powered Carvin monitors suffice since they are only intended for the singer?
Author:  jeffsw6 [ Sun Apr 05, 2009 12:54 pm ]
Post subject:  Re: Passive Floor Monitors
I just posted this suggestion (http://www.karaoke-forum.com/viewtopic.php?t=16330#235361 for another person. You seem to have a bigger budget and are looking at more reputable brands, and I guess you are happy with your existing Carvin stuff so naturally you would like to stick with them.
I didn't look up the specs on all those speakers, but I noticed you didn't supply the manufacturer stated sensitivity values for the Carvin units. The Yorkville claims a professional 100dB, or about twice the sound output for a given input energy as the 96dB Kustoms I use. Remember that's just enough for a listener to notice, but it takes ten times the sound energy for the ear/brain to perceive sound to be "twice as loud."
Your DCM 2500 amp is roughly the right size for all the passive speakers you listed. You will sooner damage the speakers by clipping the amp than by over-driving them. You could even use a slightly larger amp if you wanted.
Author:  Lonman [ Sun Apr 05, 2009 1:02 pm ]
Unless you are bridging the 2500 for the sub, you would be able to use the other channel for the monitor. If you are bridging the amp, then no.
Author:  JDrifter [ Sun Apr 05, 2009 5:08 pm ]
Thanks, Lonnie and Jeff, for your responses. I am glad that I can still use the other channel of the DCM2500 and don't have to spend more for an extra amp or for a powered speaker.
The specs for the Carvin speakers are found in the following links:
http://www.carvinguitars.com/manuals/TRX12N.pdf
https://www.carvinguitars.com/manuals/7 ... -SPKRS.pdf
https://www.carvinguitars.com/manuals/LM12.pdf
My preference would be the Yorkville NX35 or the TRX12N. Can I run a pair of speakers from one channel of the DCM2500?
Author:  Lonman [ Sun Apr 05, 2009 5:12 pm ]
As long as it doesn't go below it's 2 ohm rating for that channel, you'll be fine - two 8 ohm speakers together will yield 4 ohms total. Amps of today can run mismatched loads much better than years ago.
Author:  JDrifter [ Sun Apr 05, 2009 5:51 pm ]
Great! Thanks, Lonnie.
