File name convention for sax & Dottys
https://ksmo.us/forums/viewtopic.php?f=1&t=16313
Author:  paulmo101 [ Thu Apr 02, 2009 11:01 am ]
Post subject:  File name convention for sax & Dottys
Hi
I`m having trouble importing tracks in to show presenter without havig to rename them within the program. I convert the CDG tracks into MP3 + G tracks - end up as just track 01 02 etc. I maually rename both tracks, MP3 and CDG, To the same name e.g SF001 - 07 - Songtitle - Artist. That is disk name(Space)-(Space)Track number etc. I then creat a Zip archive with exactly the same name (SF001 - 07 - Songtitle - Artist) and zip the two files into this archive. I use Database import then get tracks to bring the files into Show presenter but the whole of the name (SF001 - 07 - Songtitle - Artist) appears in the title box and I have to manually edit the fields again before transfering them to the main database. Everything does work fine after but its a pain to keep renaming things.
Any ideas
Cheers
Author:  mckyj57 [ Thu Apr 02, 2009 11:28 am ]
Post subject:  Re: File name convention for sax & Dottys
paulmo101 @ Thu Apr 02, 2009 2:01 pm wrote:
Hi
It is not normal to have space-space between the disk ID and track. The usual format is:
DISK0000-01 - Artist, The - Title, The.zip
Author:  paulmo101 [ Thu Apr 02, 2009 11:44 am ]
Hi Thanks for the reply - let me just check I have understood the convention:
For example,
Diskname-Tracknumber(space)Hyphen(Space)Artist Comma The-Title file extension
Does that seem OK?
Cheers
Paul
Author:  mckyj57 [ Thu Apr 02, 2009 11:54 am ]
For example,
Does that seem OK?
As long as there are two space-hyphen-space combos.
DD0000-01(space)-(space)Artist, The(space)-(space)Title, The.zip
Author:  paulmo101 [ Thu Apr 02, 2009 12:02 pm ]
Hi
Big thanks for that - I`ll give it a go.
Paul
Author:  paulmo101 [ Fri Apr 03, 2009 10:41 am ]
Hi Mickey
Big thanks for replies - seems to have cured my problem.
All the best
Paul
