KARAOKE SCENE MAGAZINE ONLINE! - Yamaha EMX 5016CF Powered Mixer & BBE Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 9:40 am
PostPosted: Tue Mar 31, 2009 3:20 pm
How would I hook up my bbe into this mixer?
Gator
PostPosted: Tue Mar 31, 2009 5:25 pm
Unfortunately it can't be hooked up to this mixer for main outputs. There is no pre amp send/power amp return look nor any inserts on the mains.
Best you can do is choose whether to use it on the mics or music & put in between one of those sources & the mixer.
PostPosted: Tue Mar 31, 2009 8:53 pm
Been Liked: 31 times
Lonman is exactly right, unfortunately. Thats one of the many consideration I thought about when I went for the MG166CX and powered speakers. I use the BBE also.
PostPosted: Wed Apr 01, 2009 3:09 am
How would I do that? Thanks for your help Lonman...
Gator
PostPosted: Wed Apr 01, 2009 3:13 am
Gator
PostPosted: Wed Apr 01, 2009 11:09 am
Well, you decide if you want to use the BBE on the music or the mics. Then after that decision is made, you plug either the player into the BBE & then into the channel(s) the player was plugged into. Or if you decide you want it on the mics, then you need to get an insert cable like this
http://www.zzounds.com/item--HOSSTP20
Plug the single end into the "insert" channel of the mics - you only have two channels so you can only use it on 2 mics. The TIP plug will go into the INPUT on the BBE & the RING plug will go to the OUTPUT on the BBE.
PostPosted: Wed Apr 01, 2009 11:48 am
As an add on to what Lonman said, you could always use TWO sonic maximizers... one for vocals and one for music, which would certainly allow you some extra tweaking opportunites! :D
PostPosted: Wed Apr 01, 2009 1:18 pm
I would want to hook BBE into music but didn`t fully understand the way to do it??
Gator
PostPosted: Wed Apr 01, 2009 4:44 pm
I have the 5014 and was given a bbe unit. The Yamaha says to use aux send 1 or 2 for exernal processor and route back into mono unused channel. Aux knobs at 1:00 for music and 9:00 on mics. Aux fader at unity, return channel at unity. This does work, I can here changes when tested, so what am I sacrificing by doing this? I will be getting a drive rack soon as I just bought QSC speakers but would still like to know
Users browsing this forum: No registered users and 2813 guests
