KARAOKE SCENE MAGAZINE ONLINE! - MA3000K or GEM SOUND EXA3955 3,000 WATT or TECHNICAL PRO PA-2000 Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 10:40 am
PostPosted: Sat Mar 21, 2009 8:46 am
Hi,
I'm looking for a budgeted karaoke system. Your suggestions on the following items would be greatly appreciated. Thanks.
1/ Hisonic MA3000K which has a pre-amp built in, echo, and tone controls and runs at $350
2/ GEM SOUND EXA3955 3,000 WATT is just an amp and runs at $178
3/ TECHNICAL PRO PA-2000 is also just an amp and runs at $189
PostPosted: Sat Mar 21, 2009 9:01 am
roberco @ Sat Mar 21, 2009 11:46 am wrote:
Hi,
4/ None of the above.
I don't think you will find a recommendation for any of those brands here. Try this:
http://pro-audio.musiciansfriend.com/pr ... sku=630486
PostPosted: Sat Mar 21, 2009 9:53 am
Note: Although Micky's suggestion is actually an amp/mixer rated at 200W instead of 2000, it's rated properly.
Don't know about the other, but Technipro's rating is a bit skewed. That 2000w is MAX at 2 ohm impedance. This means the MAX ( not RMS ) rating at 8 ohm is around 500w. Which means the RMS rating at 8ohms could well be 200 to 250W - the same as the unit Micky suggested.
PostPosted: Sat Mar 21, 2009 10:00 am
Yeah sorry, none of those will be of any quality sound. The little package Micky linked to is a decent little PA then you can use your computer/laptop for the karaoke player.
PostPosted: Mon Mar 23, 2009 6:56 am
Thanks guys for your valuable comments. I already have two 3-way speakers which require an amp of at least 200W. I found a BMB (RSQ DX-333) 600w output, 2 x 300W, mixer online that has everything build in. I could find any reviews on this one. How do you think about this one? Thanks again.
PostPosted: Mon Mar 23, 2009 7:22 am
BMB is another brand that no one here is going to recommend.
Are they PA speakers? Or stereo speakers? Stereo speakers (ones without a horn tweeter) are usually not suitable for live vocals. And I am not sure you are reading the specs on your speakers correctly. Do they have an RMS, program, or peak rating? If it is Peak 200w that means you want a 100w/channel amp. The Sherwood RX4105 will drive those -- it is only $99.00 or less.
PostPosted: Mon Mar 23, 2009 9:11 am
The speakers are 3-way PA speakers (PA 1200c). Here are the specs of this pair.
- 500W RMS max at 1000W RMS
- Sensitivity 92db with 32-30,000 Hz frequency response
- 12" 8ohm woofer
- Includes 5" midrange and 3"x7" horn tweeter
- Requires an amp that can produce a min of 200W at 8 Ohms.
PostPosted: Mon Mar 23, 2009 9:20 am
- 12" 8ohm woofer
No speaker has those specs, really. I am guessing they are no-name speakers that don't even begin to meet what they claim.
Your guess is as good as mine as to an amp to drive them. You could get a Behringer EP2500 for $250-300 or so on EBay. That's as good as guess as any for an amp to drive them. At least if the speakers don't work out, you can buy most any pair of decent PA speakers and get a reasonable sounding system.
PostPosted: Mon Mar 23, 2009 9:33 am
Actually, BMB = Nikkodo = RSQ, who have been putting out karaoke equipment forever. . ( The made a NICE triple tray player, remember?)
I won't say it's the greatest, but I think the RSQ mixer will meet your needs, given that you're on a budget.
I would be very careful of those speakers though. I have a feeling they may be like TechniPros.
I was once given a pair of their MAX 8s. Supposedly 300 watts, but couldn't handle 75 watts- PPFFFFT!
PostPosted: Mon Mar 23, 2009 9:53 am
Atually JVC made the triple tray FOR RSQ under license, when the license expired, JVC decided to quit making the line altogether for themselves & RSQ.
The karaoke mixer/amp again is not going to be great for sound. Anything that says "made for karaoke" or has "pro-karaoke" is typically not very good for karaoke - at least for good sound. It's often very overpriced & underfeatured.
For the price listed on that unit alone you can get a nice little mixer & amp combo that will sound much better, have better effects section for the vocals & more versatile to grow with.
Mixer
http://pro-audio.musiciansfriend.com/pr ... sku=630156
For a little more here is one on a scratch & dent sale - full manu warranty & you can get extended warranty through the store if desired. Usually these are very minor blemishes.
http://pro-audio.musiciansfriend.com/pr ... ku=630166X
This mixer is also USB capable to connect to the computer.
Power Amp
http://pro-audio.musiciansfriend.com/pr ... sku=481804
Being conservative on the amp ratings because the ratings for the speakers you listed don't really make sense.
So for about $400, this amp & mixer combo will sound great - especially compared to the BMB mixer amp. The only thing karaoke mixers incorporate that regular mixers do not is typically a key changer - which is generally built in to most players & available on most karaoke software on the computers. Not needed in the mixer.
PostPosted: Tue Mar 24, 2009 10:22 am
Yup, and Nikkodo took it over from there. Good point though, quality could possibly slipped from that point forward... dam!
Unfortunately, Pioneer went the same way....
PostPosted: Tue Mar 24, 2009 4:12 pm
Guys,
The speakers that I have are Pro Audio speakers (no brandname I admid) and each speaker is rated at 250W with a max of 500W. After searching on the net, I'm narrowing down to these two power mixers:
Phonic Powerpod 780 Plus 2x300W 7-Channel which runs at $297
Behringer EUROPOWER PMP2000 which runs at $314
Do you have any recommendations? Thanks.
PostPosted: Tue Mar 24, 2009 4:59 pm
roberco @ Tue Mar 24, 2009 5:12 pm wrote:
Guys,
If those were my only choices I had to choose from, the Behringer pushes 165 watts per channel, the Phonic pushes 200 watts (although they do not say if it's max or not), i'd opt for the Phonic.
Users browsing this forum: No registered users and 3081 guests
