| Flutter https://ksmo.us/forums/viewtopic.php?f=1&t=16149 |
| Author: | karyoker [ Fri Mar 13, 2009 10:40 am ] |
| Post subject: | Flutter |
With a CFX12 I had typical flutter like when driving EFX too high. I am running EFX 1 to a Microverb4 which has the bar indicators for input level. Returned to EFX2. On the strips I am running the EFX send at unity. I had to turn EFX send down to where the bars were at only about 50% on the input to get rid of the flutter. For some reason I am having trouble with gain structure as far as EFX send. |
| Author: | Lonman [ Fri Mar 13, 2009 11:12 am ] |
| Post subject: | Re: Flutter |
karyoker @ Fri Mar 13, 2009 11:40 am wrote: With a CFX12 I had typical flutter like when driving EFX too high. I am running EFX 1 to a Microverb4 which has the bar indicators for input level. Returned to EFX2. On the strips I am running the EFX send at unity. I had to turn EFX send down to where the bars were at only about 50% on the input to get rid of the flutter.
For some reason I am having trouble with gain structure as far as EFX send. Why are you running the EFX 1 send to the EFX 2 return? Run it to the EFX 1 return - or if you have open channels, run them back to a channel strip. But will work with the return for now. On the try setting the input at 12:oclock to begin. Run the mix wide open & output to 3/4-wide open. On the channels you want to effect, turn the EFX 1 knob up to about 9-10 oclock. On the Master EFX 1 send (right above the internal effects section) turn up to 12 oclock. The EFX 1 return (next to the meters) turn up to about 12 oclock. See how this does. If the input meter on the Microverb jump into the red, turn the input down a bit & you can compensate by the output knob & EFX 1 return. |
| Author: | karyoker [ Fri Mar 13, 2009 11:54 am ] |
Lonnie I dont remember but I think the internal EFX are controlled with EFX2 which is why I was using that return. My preferred way is returning EFX thru a spare channel strip but I am training hosts right now that dont even understand sub sends let alone EFX. In fact if I dont go to my show for a few weeks the sound deteriorates Do you have this problem with your fll in hosts? |
| Author: | Lonman [ Fri Mar 13, 2009 12:24 pm ] |
karyoker @ Fri Mar 13, 2009 12:54 pm wrote: Lonnie I dont remember but I think the internal EFX are controlled with EFX2 which is why I was using that return. The internal effects are controlled by EFX 2 send. If you plug the returns from EFX 1 send from your Microverb into the EFX 2 return, you are going to be piggy backing the external & internal effects - possibly why you are getting the flutter. Patch the Alesis into the EFX 1 return. If you don't want to use the internal effects, you can just bypass. Quote: My preferred way is returning EFX thru a spare channel strip but I am training hosts right now that dont even understand sub sends let alone EFX. Ugh. I hate training!!!! Quote: In fact if I dont go to my show for a few weeks the sound deteriorates Do you have this problem with your fll in hosts?
Sure. But that just makes you look THAT much better !
| Author: | karyoker [ Fri Mar 13, 2009 12:54 pm ] |
Thanks Lonnie I knew you could straighten me out. Sometimes you cant see the forest for the trees and one over complicates a simple problem. |
