KARAOKE SCENE MAGAZINE ONLINE! - Lcd Monitors Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 3:07 pm
 Post subject: Lcd Monitors
PostPosted: Mon Mar 09, 2009 5:23 am
I see a 17"LCD Flat Screen monitor for $79.99 and Kcom has the stand on sale for $68..SO NOW might be the time for me to go for it ~~
I would THINK that any LCD is good for karaoke spec wise ????
It has VGA inputs and VESA mounts ??
Is there anything else I would need to be aware of ?
 Post subject: Re: Lcd Monitors
PostPosted: Mon Mar 09, 2009 5:35 am
If you are happy to run VGA (I only say this because cables can get pricey if you are looking for a distance) then that will suffice.
It's low qual graphics we use anyhow :)
PostPosted: Mon Mar 09, 2009 6:19 am
I would prefer to use s video or other --But finding a monitor that accepts would cost more than the $23 15ft cable I saw ??
PostPosted: Mon Mar 09, 2009 6:37 am
Fair play then. But how much are you seeing VGA cables of similar lengths for?
PostPosted: Mon Mar 09, 2009 6:51 am
I saw on-line a 15ft VGA cable for $23.
PostPosted: Mon Mar 09, 2009 7:52 am
That's a good price for a decent VGA cable :)
PostPosted: Mon Mar 09, 2009 8:37 am
This is what I saw ???
http://www.cablestogo.com/product.asp?c ... &sku=09618
PostPosted: Mon Mar 09, 2009 9:16 am
Not questioning you friend :) Simply stating it's a good price :)
PostPosted: Mon Mar 09, 2009 9:17 am
Been Liked: 20 times
I'm running 2 lcd monitors, 1 regular and 1 hdtv, I think you should go for it, looks like a good price to me. Are you getting the monitor locally, if not, make sure you're not losing money on shipping costs. Lcd monitors are pretty cheap now, and can usually be found locally.
Rosario
PostPosted: Mon Mar 09, 2009 10:42 am
lol --Just showing you in case you neede one :D
PostPosted: Mon Mar 09, 2009 10:49 am
What is the downside of a WIDE SCREEN flat panel ?
PostPosted: Mon Mar 09, 2009 10:52 am
It just gets a little tricky when you have both standard screen and wide screen monitors in the same mix since the resolutions are different.
For example, if your laptop is standard, and the tv (or lcd) is widescreen only, then you will have to fiddle with your resolution settings on the main and extended screens to get them both to look right.
PostPosted: Mon Mar 09, 2009 12:05 pm
THANKS
PostPosted: Mon Mar 09, 2009 8:52 pm
Cable is cheap.
50 Ft Vga cable is $12
http://www.monoprice.com/products/produ ... 1&format=2
Great company I get everything I need from them.
PostPosted: Tue Mar 10, 2009 6:59 am
None since you can set the resolutions differently and the video will scale them appropriately. The only potential hassle might be if your software doesn't support the resolutions. But I have to admit it would be bizarre if that occurred given the level of driver support now.
PostPosted: Tue Mar 10, 2009 12:31 pm
lyquiddye @ Mon Mar 09, 2009 10:52 pm wrote:
Cable is cheap.
I second that. Plus lifetime warranty on all cables.
Users browsing this forum: No registered users and 2352 guests
